Can someone advise if a kph digi trip meter can be converted to a mph one? My mph one has bust and I have found a kph one in a breaker. Better still, anybody want to sell a mph one?
Thanks for any help in advance!
If you take it apart there is a small resistor on the circuit board in the top left hand side that has MPG/KPH written beside it. I'm not sure if this works. The only thing i have done is by changing into the digital speedo which is in KPH but then i can use it when southern ireland is not very far away.
Simon. Thanks very much for the help. I have ordered from the breaker.
If you do a search you will find information on taking it apart and the speedo mod.
As said above, you can switch between miles and kilometers by changing a link on the PCB. I think there is link to the modification on the ATiC site.
Note that this only changes the distance trip meters. You can enable a speed readout on the Tripmaster but it will always be in KPH.
Thanks guys. Found the link and I will take the old one apart tonight for investigation. I will do the speed mod on the new one as well.
I did the speedo mod on mine today.
Cost 9p for a resistor and took about an hour to do from start to finish.![]()
