Results 1 to 10 of 11
Thread: HELP! Rear brake pads wont fit
    kiroh's Avatar
    Apr 2004
    London
    MOT is due on my bike, so I've decided to change the brake pads. The rear one gives me a headache though - with the new pads on, the brake caliper won't fit. Seems like the left pad is 1-2 mil too thick.
    Pads came from David Silver, and I don't think they've made a mistake with part numbers, etc.
    Has anyone had this problem before?
    Simon Guest
    I take it you have the pistons fully in?
    nellychat is offline Member
    Jan 2006
    Yeovil, Somerset
    I had exactly the same problem, everything fitted correctly, piston fully in and the pads wont fit.
    Probably not the best solution but I took the pad to the bench grinder and shaved 1-2mm off the face. Fits a treat now
    kiroh's Avatar
    Apr 2004
    London
    Quote Originally Posted by nellychat
    "Good" to hear you had a similar problem nellychat. Do you think it's to do with damaged calliper?
    Don't have a bench grinder, so probably will use the old pad on one side and new one on the other. The problem is that there isn't much "padding" left on the old one.
    kiroh's Avatar
    Apr 2004
    London
    Quote Originally Posted by Simon
    Yes indeed - piston fully in, and both pads fit over the rear disk, but the calliper wont slot all the way in, as it's misaligned 1-2 mil because of the left pad. (Does this make sense?)
    Simon Guest
    sounds a bit crap. I changed my pads recently but didn't have any problem. Unfortunatly its one of those things you can't do without!
    Cotswolds, UK
    Is the slider pin that holds the caliper onto the bracket still ok? I suspect the exposed bottom bit has been corroded to a level where it cannot go any deeper, giving too little room for the new pads to fit. The pins is easy and cheap to replace, use a bit of copper paste or (better) silicon grease when putting it back together. Make sure the rubber bracket "boot" has no holes otherwise you may soon need another new pin.
    You could ignore the cause of the problem and fix the symptoms by grinding down the pads (!!), but in a later stage the caliper will get more and more difficulty moving on the pin, putting more braking force on one side on the disc than the opposite side. This will most definitely warp the disc.
    Good luck & cheers
    Ps! I don't mean the pad-slider pin, but the slider pin between caliper and mount.
    Jan 2006
    Yeovil, Somerset
    Thats sounds very likely, think I had better look at that!
    kiroh's Avatar
    Apr 2004
    London
    Thanks robelst - after changing the sliding pin the caliper slides far enough to the right to fit the pads. The old sliding pin was corroded and I got a new one + rubber sleeve from the local Honda dealer for a tenner.
    Cotswolds, UK
    Glad to see you sorted the problem, it's always rewarding to share experiences with problems and other related misery
    I only hope it didn't stop you riding your bike for the last 5 months (looking at the topic date)?
  1. brake pads
    By 5135jimmy in forum Africa Twin
    Last Post: 10-01-07, 10:06 PM
  2. Brake pads
    By lowflyer in forum Africa Twin
    Last Post: 25-11-06, 10:23 PM
  3. Brake Pads
    By pooh in forum Africa Twin
    Last Post: 18-09-06, 05:59 PM
  4. Brake pads - when to replace?
    By ChrisH in forum Chatter
    Last Post: 06-05-06, 02:02 PM
  5. Brake Pads - Recommendations?
    By DaveS in forum Africa Twin
    Last Post: 04-01-05, 05:15 PM
