Results 1 to 4 of 4
Thread: MOT Pass!
    Richie B's Avatar
    Richie B is offline Senior Member
    Jul 2005
    Salisbury, Wiltshire, United Kingdom
    MOT Pass!
    Well, I dug her out of the back of the garage, brushed away the cobwebs and took her in for the pre-season MOT. Passed first time - not bad considering she ain't been used for a few months. All was peachy until........
    ......... major loss of power 5 mins after pulling out of the workshop. A quick u-turn for the mechanic to have a look and it seems i'm down to one cylinder! I'm no mechanic (my knowledge of engines is such that I know where to put the petrol and that's about it) but he's going to have a look before next weekend and sort it out. He guesses it may be a plug or the carb needs a strip down and clean (way above my 'Haynes one-spanner' expertise).
    Has anyone else experienced this? Suggestions/recommendations? Bit hacked off that I had to get the bus home.........
    2003 KTM 640 Adventure
    2011 AJS JSM 125 Trail (Salisbury Plain Toy)
    Slimie is offline Huh?
    Devon, proper job!!
    Yeah!
    I left mine for three whole weeks and then rode down to the Hook hook-up, all the way down the M3 the bike felt sluggish
    Once I stopped I noticed how tight the cables that supply the heated grips were. Turns (!) out that the grips are slipping around the bars and need an occasional tweek in the right direction!!
    YMMV!!
    -Simon
    Re: MOT Pass!
    Quote Originally Posted by Richie B
    I used to get something similar, it was the low tension spade terminals on the front coil getting the road salt treatment. A scrape with a scalpel used to sort it.
    nellychat is offline Member
    Jan 2006
    Yeovil, Somerset
    At least yours starts. Looking forward to sailsbury plain next sunday, thought I had better dig the @ out, maybe even a wash.
    Hit the starter and it hardly turned over Tried to bump start but no luck. I was a little over cautious as I dropped it last time.
    Had to dig the road start out from the back of the garage, dont like to use it on the bike, bit like a sledgehammer to crack a walnut! But it fired up straight away, left it running to 20 mins and all seems well again.
    I guess it was rebelling after being left in the cold garage for 3 weeks. I have also made a bench for the garage and been using the @ as a workmate!!
    Needless to say we are barely on speaking terms and there was no wash!
  1. MOM gets his bus pass tommorrow
    By Sharribee in forum Chatter
    Last Post: 04-07-06, 09:34 PM
  2. eyeball - snakes pass derbyshire
    By sean in forum Transalp
    Last Post: 08-05-06, 01:00 PM
  3. TIZI N TEST PASS (S501 IGN 3615)
    By Darkenbad in forum Great Roads/Routes
    Last Post: 27-01-06, 09:16 PM
