Yeah, thing is the position of the sensor is adjustable (slotted mounting holes). Rather unhelpfully, there's no instructions for setting it up in the haynes manual, it just says "don't mess".
On the TL (yep, different bike I know, but same principle) the TPS is set up once the throttle bodies have been synchronised and the idle speed set. On those, you can bridge a connector under the seat to turn the temperature gauge into a display of which way the TPS needs to be moved. On the AT, no idea.
