I thought only a fuel injected vehicle would have/need a throttle position sensor, but nope, there it is in the Haynes - 'Throttle position sensor'.
As for why, I haven't the foggiest! Must be for the CDI system, so it knows what you're doing with the throttle and can time itself accordingly, at a guess. |
Yep, the TPS helps the ignition system get the optimum ignition timing.
Without it, timing can only be engine speed and conceivably engine/air temperature related, but with a TPS, it can be load related too. Enables it to be nice and retarded at low loads to avoid pinking, but nice and advanced at high loads to generate best torque (power). Old cars used to have a vacuum operated advance unit (which actually retarded with increasing vacuum) to do the same thing. |
Quote:
From what year do AT's have this feature? I don't think my '94 AT has this (unless it fell off). This brings me to David Silver, selling out AT carburettor banks for the R/S model ('94/'95) and a seperate one for the T model ('96). Looking at the exotic price tags of loose carb-parts I wonder if the £149 wouldn't be a sensible investment on my 50k / 11 years old bike that will need to last another couple of years. And then of course whether the T-bank may have this feature and might actually be the better choice, even on R and S models? I wonder if it helps mpg as well, later ATs always seem to be more economic than early ones |
Quote:
As for retro-fitting it, you'd need to retro-fit the whole ignition system too, as the earlier CDIs won't have an input for the TPS. |
Quote:
RD07's don't have 'em only RD07a's from 96/97 onwards. Quote:
Quote:
Jim |
Chronyx wrote
Quote:
__________________
01 XRV750 Africa Twin. RWB Dynojet+Airbox Mods, Heated Grips, Scottoiler, MRA Varioscreen, Motad Desert Bars, Autocom Kit6, Garmin Zumo 400, Kenwood B2B, Mitchelin Anakees. |
Quote:
I think that when I replace the carbs I'd go for the good-ol' "Neanderthal" version, hardly seems worthwhile to change the CDI as well (unless I am "lucky" enough to break that as well |
Quote:
| Bookmarks |
| Tags |
| position, thingy, throttle |
| Thread Tools | |
| Display Modes | |
| Poor throttle response? | fewtrees | Africa Twin | 21 | 11-12-08 08:26 AM |
| Replacement Throttle Position Sensor (TPS) | darthDassie | Africa Twin | 0 | 19-12-06 06:58 AM |
| Throttle Take up | Shepp | Africa Twin | 3 | 28-05-06 06:05 PM |
| Cap thingy replacement | Richie B | Africa Twin | 8 | 22-01-06 04:47 PM |
| Throttle Cables? | gibbo | Africa Twin | 2 | 27-04-05 12:06 PM |
