Results 1 to 9 of 9
Thread: running to rich
    c stillythemanwivno Guest
    running to rich
    i have been having trouble starting her so i checked one spark plug black and sooty so it is running to rich ,i was just wondering what screw on the carbs do i adjust to make things better
    Carport is offline Senior Member
    Newport
    You can only adjust the pilot jet(this controls the mixture at tick over) with a screw(small brass screw on the bottom of each carb). From memory I think they should be 2 1/2 turns out from fully in
    Is the bike standard?
    If so it should be fine as is, so check your air filter is Ok and that you have the correct spark plugs, and also check that you haven't got sticky chokes as described elsewhere on the forum.
    If the bike is non standard let us know whats been changed
    thanks mr carport i have a k+n air filter remus end can !
    Newport
    Quote Originally Posted by c stillythemanwivno
    Is the can race or road?
    Whatever, if anything it should be running ok if not a bit lean.
    So you may have a problem, check the air filter is clean and then I would investigate the choke mechanism at the carb end where the cables enter the carb bodies. They can stick and cause rich running.
    Slimie is offline Huh?
    Devon, proper job!!
    I wish I was running to rich.
    All I can seem to manage is running to fat.
    -Simon
    lootch67's Avatar
    South Ockendon, Essex
    Jog and die healthier
    Quote Originally Posted by Carport
    its a road can i think
    Devon, proper job!!
    Quote Originally Posted by lootch67
    With knackered knees and hips! You do know that the man that promoted jogging dropped dead with a heart attack while out on a run!
    Hope I die before I get old, as someone once sang!
    -Simon[/i]
    posiwev is offline Senior Member
    Jan 2005
    heywood
    Take yer carbs off and give them a good clean out with carb cleaner and air also check the chokes and cables are working correctly.
    Andy
  1. Rich Running
    By nellychat in forum Africa Twin
    Last Post: 10-01-07, 10:34 PM
  2. Replies: 6
    Last Post: 04-09-06, 04:35 PM
  3. I'm rich I'm stinkin rich!!!!
    By Maverick in forum Chatter
    Last Post: 18-07-06, 07:01 PM
  4. Hello from rich -Gloucester
    By wobbly chopper in forum Varadero
    Last Post: 20-02-06, 07:23 PM
  5. running in
    By kev in forum Transalp
    Last Post: 20-11-05, 04:13 PM
