Most bolts need a tap and a twist to get them out of something that has no lube and a tight fit. Start off with a glamorous assistant with a hammer and a piece of softwood, hammering the end of the bolt you have removed the nut from as you turn the other end. It should start moving quite easily. Once the end disappears into the mount you might have enough on your side to pull as you turn the thing at the same time. If it still needs hammering, I use a socket extension bar which can follow the bolt through.
