Results 1 to 10 of 10
Thread: Fuel pump running issues
    chronyx's Avatar
    Surrey, UK
    If you have replaced your fuel pump - did you have any running issues at all before it packed up?
    John's Avatar
    John is offline Senior Moment
    Jan 2006
    Brighton
    No. In my case it just stopped running with no warning.
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    I was sure my fuel consumption and power was affected but ever so slightly and it could of been other factors such as dirty airfilter etc etc also. Mine also worked the one moment and died the next Happy to confirm [touch wood] the pierburg is still running fine after 12k miles without any additional relays etc[/touch wood]
    My first stopped dead, my second played up intermit..inter... ran oddly before going, my 3rd (vacuum type) also played up before I replaced it. 40,000ish miles seemed to be the time they started to die.
    Cotswolds, UK
    Mine started to play-up intermittently. I discovered I could revive it by knocking on it with a blunt object: I have been driving with a socket on my finger so I could do it while riding. I have always favoured cave-man technology
    While I was waiting fot the delivery of my Pierburg replacement it seemed to be running fine again but I'd lost faith in it.
    Not sure though if all OE (Mitsubishi) pumps die in the same way
    Lord Stig's Avatar
    May 2004
    West Lothian
    I had a flatspot on acceleration after shutting the throttle - not sure if it was related to the pump, but it appears to have disappeared now I've fitted the Facet. I also changed the front coil though, so it could have been that.
    Stig
    intermittently.
    show off.
    chronyx's Avatar
    Surrey, UK
    Humph. Maybe my carbs need balancing then or something. Bike coughs every now and then and just doesn't sound right.
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    Quote Originally Posted by YEN_POWELL
    intermittently.
    show off.
    Them graduates...........
    BlindPugh's Avatar
    UK
    Replaced 2 pumps - first one went after a couple of weeks of a very occasional misfire at 6000rpm in top gear. Seemed odd at the time as the bike had never missed a beat. Eventually stopped completely and then had sixty miles of riding very slow and then stopping, waiting for pump to cool down then running for another 6 or 7 miles.
    Second one just gave up with no warning at all - by then I had sorted Plan B - bypass the pump and fill the tank to the top. Gravity feed for about 100 miles or refill after 70-80 miles.
    Last Post: 14-03-09, 09:27 AM
  2. fuel pump
    Last Post: 14-01-07, 07:21 PM
  3. Fuel pump
    Last Post: 07-07-05, 11:55 AM
  4. AT fuel pump
    By sa6andy in forum Africa Twin
    Last Post: 11-05-05, 01:35 PM
  5. is it the fuel pump?
    By kiroh in forum Africa Twin
    Last Post: 28-02-05, 12:50 PM
