Results 1 to 5 of 5
Thread: New Chain
    zorza's Avatar
    zorza is offline VespaOwner
    Dec 2005
    Porto - Portugal
    New Chain
    so, my chain is almost running out it's last miles, as it can't be streched anymore.. Next time I mess with it, it will have to be for a complete change..
    By chainging the chain, I also need to change the front and the back sprocket (is it written correclty??)
    I know Africa Twin uses DID 525 (saw that on wiki)..
    What I really want is to able to buy one on-line and to know really what I am buying. I don't mind paying some more, if it reasures me that it is of better quality and will last longer without having to touch it...
    So, 2 small questions:
    1- wich chain (with a reference will be fantastic)
    2 - anyone bought it online? www adress??
    Zorza
    red dragon is offline Junior Member
    Jul 2006
    home
    i used to run an o-ring chain on my bikes untill i discovered the x-ring chain. it is a tad more expensive but i get way more miles off it compared to the o-ring chains, provided i keep it well greased up. i dont use chain wax, only an off road chain lube that is seriously good stuff,i found wax just wasnt up to the task, especially when you ride in the dirt!!
    have no idea as to a www address but if you do a search in here or perhaps on google....hang on a sec....go to www.didchain.com they give you the gen on their chains as well as world wide distributors!!
    Cie's Avatar
    Cie
    Cie is offline Advanced riding bore
    Amesbury, Wilts
    Hiya Zorza,
    I bought my chain, and sprockets on-line from M&P
    '08 KTM 990 Adventure S
    cabbage2404's Avatar
    cabbage2404 is offline Senior Member
    Jan 2006
    South Wales
    Got mine from Wemoto.
    GS owner (The Suzuki one, not the Bavarian Monster)
    lootch67's Avatar
    South Ockendon, Essex
    The main factor in determining the life of a chain is how well you treat it i.e. keeping it clean, lubed and the chain tension correct. All things being equal it would appear as if the DID X-ring chains lasts a bit longer and are worth the extra cash. All the suppliers mentioned are reputable. You could also try David Silver Spares.
  1. New chain etc
    Last Post: 23-06-10, 05:41 PM
  2. Chain kit - where do I get one from?
    By keewee in forum Transalp
    Last Post: 28-07-06, 09:54 AM
  3. Chain and Sprockets in the USA
    By paul_r in forum Africa Twin
    Last Post: 25-07-06, 11:54 PM
  4. CHAIN FOR AT.
    By ruterovenezuela in forum Africa Twin
    Last Post: 06-04-06, 07:26 PM
  5. Chain(again)
    By mal in forum Africa Twin
    Last Post: 17-03-05, 09:51 AM
