Decided not to use all the complex pipe arrangement of the front brakes on my rebuild - so anybody got recommendations for braided hoses? My plan is to go from master cylinder with a double banjo bolt to both calipers without using any of the soild pipework on the back of the lower fork yolk. For the rear I need a new hose so might as well get braided here too.
Can anybody see major pitfalls with the above ideas - I know The brake pipe clamping will probably be a bit different - planning on using a rubber lined P-clip if I can find some.
