Results 1 to 10 of 31
Thread: Chain and Sprockets
    iswoolley's Avatar
    Jun 2004
    Telford, Shropshire
    Chain and Sprockets
    It's time to replace the chain and sprockets on my 2002 RD07a. I don't want to skimp on the quality of the bits, so I was thinking of going for a DID chain and JT sprockets. To be fair I originally wanted to fit Honda parts, but the cost of front (£23) and rear (£70) sprockets scared the bejesus out of me!
    Having checked on the M&P website, the whole lot comes to:
    Chain: DID 525VMx124 - £70.00
    Front: JTF 314.16 - £15.00
    Rear: JTR 1332.45 - £15.75
    P&P: Standard - £4.99
    Total: £106
    But, before I place my order in the morning I thought I'd see if anyone has had bad experiences with either DID, JT or M&P. Or is there another supplier out there that can provide my bits even cheaper.
    What do you reckon?
    Chad's Avatar
    wickford,essex
    ive always used DID chains top quality jt sprockets are fine to but stick to the OE front sprocket its a bit more pricey but its the proper job .
    if you do it will look like its not seeting properly on the front sprocket
    just fit it then run it in for about 10 mile then check and re adjust the chain. you will then find the chain seeted nicely around the front sprocket on the rubber cush either side of the sprocket
    i did this with mine and double checked it all just before i sold it and all was well . are you going for the gold xring ? pricey but worth it in the long run
    Chad's Avatar
    wickford,essex
    sorry iswoolly not trying to teach you to suck eggs dude
    Slimie is offline Huh?
    Devon, proper job!!
    Quote Originally Posted by Chad
    Chad, how do you suck eggs?
    -Simon
    Chad's Avatar
    wickford,essex
    Quote Originally Posted by Slimie
    -Simon
    dunno the only ones ive sucked are the caburys miini eggs and i allways end up chewing
    iswoolley's Avatar
    Jun 2004
    Telford, Shropshire
    ...jt sprockets are fine to but stick to the OE front sprocket its a bit more pricey but its the proper job...
    This is the kind of comment I was looking for. Are JT sprockets not up to the job? Why use the Honda one instead? How much difference does the rubber on the Honda sprocket make? If it's so good, why don't the pattern sprockets have it as well?
    Thanks for the input Chad.
    Chad's Avatar
    wickford,essex
    Quote Originally Posted by iswoolley
    when i changed mine it had a jt sprocket on after removal i noticed very slight wear on the output shaft .the honda sprocket seemed to fit more snug and i think that the rubber cush helps to keep the sprocket in line to cut down any laterall movement , these were my findings and i felt much happier that i had the right kit on the bike
    barftone's Avatar
    Apr 2005
    Bath, England
    Go wiv Chad. Make sure you get a OE front sprocket and yah boo to Wooley bloke
    Razzledazzle's Avatar
    Razzledazzle is offline Junior Member
    Apr 2006
    Brighton
    Have a look here for a fairly lengthy discussion on the Honda OEM front sprocket http://www.horizonsunlimited.com/hub...front+sprocket
    BlindPugh's Avatar
    UK
    I am with Chad on the front sprocket thing - saving a couple of quid for front sprocket is not worth it. I went with the OE chain and spocket last week - price seemed reasonable to me ( but then I can get 40K miles out of chain and sprockets). If I still had the Dominator I would be probably buying chain in bulk as it seemed to have a real appetite for it!
LinkBacks (?)
  1. Which chain and Sprockets........
    Last Post: 10-12-06, 07:06 PM
  2. Chain and Sprockets in the USA
    By paul_r in forum Africa Twin
    Last Post: 25-07-06, 11:54 PM
  3. Chain and sprockets HELP!!
    By banger in forum Africa Twin
    Last Post: 19-02-06, 06:21 PM
  4. chain and sprockets
    Last Post: 04-01-06, 11:38 PM
  5. Help ! Chain & Sprockets
    By wheeliebin in forum Chatter
    Last Post: 10-11-04, 07:12 PM
