What pressures do people put in the TKC80's when using them on-road? Just wondering...
2.2 and 2.5 on the NX
Michel
'89 NX650 -- R.I.P. -- Gone
Is that kg/sq cm?
If so, that's 31/35 PSI. I stuck 38 in both at the garage earlier, perhaps a tad too much...
Bar.
$ units
500 units, 54 prefixes
You have: 2.2 bar
You want: psi
* 31.908302
/ 0.031339806
You have: 2.5 bar
You want: psi
* 36.259434
/ 0.027579029
Michel
TA 600
33 psig front
36 psig rear fully
loaded for high speed road use
drop that by 10 psig for off road
great tyres but soon square off and give an interesting wobble fully loaded at 101-103 mph!! so cruised at 85-90 mph and at very low filtering speeds.
look the bollock too![]()
just my tkc's done @ micheldever & they said 30 on the front & 36 rear.
oh & they are only speed rated to 93 mph
mine has 119mph on them .. they are a but interesting at very low speed when they are new and chunky.. only exceeded 95 mpd ( 101-1030 on a short trial .. not happy with thehandling fully loaded so most was 80-95.
will check mine again to see what's on the side walls..
ray
My TKC front wheel says 40 psi on the tyre wall when cold so that's what it is inflated to.
Ran mine at 30 Front/36 Rear. Fully loaded with luggage or not they didn't feel any different....AND I got 11,500 mile out of the pairProbably more like 15,000 out of the front as I put that back on with a new rear just before the AT was nicked. Hopefully it disintegrated as the thieving wretches made a high speed getaway!
