Originally Posted by
Cie
Now I've bothered my arse to look at what's needed, I've done most of the service in an afternoon, just need to do the plugs, air filter and brake fluid. Shouldn't be too hard, apart from all that bleedin bleeding.
Just fit a pipe to the caliper nipple, immerse the other end in a jar of brake fluid to stop air getting into the end (or get one from Halfords with a non return valve for a few quid), undo the nipple and keep pumping fluid through whilst making sure the master cylinder is topped up. Keep going till all the old fluid is pushed out. Take your time and you may not have to bleed it at all (unless you think it needs it).
Empty the brakeline first and you'll be there for ages trying to get the line to fill again, unless you have one of those expensive suction bleeders.
