Problem: my tripmaster has not increase km stand over few hundreds km.. if ever than only for 0,1km on 100 - 200km. I coudn't operate him via buttons... he was frozen... (I coudn't change time, trips etc.. )
I coudn't find answers on Inet, only questions.... because I'm electro engineer, I tried it to repair by myself. First question was how to bring tripmaster to life on table with 12V power supply.. .. OK.. not so difficult... +12V on +B , ground on GND... but you have to make bridge between +B and IG pins, than tripmaster gets info that you "turned a key"... (links from display when you look from display side)
Next problem was that I downloaded datasheet from Toshiba about TA6005F (IC2) which is 5V voltage regulator with watchdog timer. The japans are strange they mix Vcc on Uot... but at the end they made not out of standard and pin 14 is 12V supply for IC and pin 4 is 5V output voltage.. complete tripmaster has normal TTL logic, like I found out.... that mean when I measured 1,9V at buttons, there was a fail... at the end I found out, that Electrolyte capacitor (C9?) was broken...
My @T is produced in 1994... and its only question of time when Electrolyte capacitors will loose a liquid especially in higher temperature.... therefore I suggest to everybody to replace electrolytes before start to change expensive IC's.. you can find out if one electrolyte is broken, that if you start to solder him with soldering iron, it smells like two weeks fish on sunshine...
photo:
TA8005F datasheet:
http://www.datasheetcatalog.com/data.../TA8000F.shtml
there I had confusion at pin 14 is wrote OUT and pin 4 Vcc... I THINK it should be oposite...
!Boris!
