Results 1 to 10 of 33
Thread: Help on installing progressive springs
    mladen is offline Member
    Slovenija
    Hello!
    I need help on installing progressive springs on my AT 1998. I don't know which way is the right to put them in the fork. The more densed side down or up?
    Thanks for your help!
    Hagalaz's Avatar
    Hagalaz is offline Member
    May 2006
    North Somerset
    IIRC, the tighter coils go to the top.
    Every cloud has a silver lining (except for the mushroom shaped ones, which have a lining of Iridium & Strontium 90)
    Pussyhorse's Avatar
    Essex mate
    Yup, tighter coils at the top.
    Slovenija
    Thanks a lot for the answers!
    I was pretty sure that the tighter coils go in the bottom. I'm glad I asked for an advice!
    Rubberchicken's Avatar
    Amsterdam
    The trick is that you want the unsprung bit (i.e., the wheel) to be as light as possible, and the tight bit of the spring is heavier than the open bit.
    Michel
    '89 NX650 -- R.I.P. -- Gone
    Slovenija
    My english is limited, so i didn't quite understand the part "The trick is that you want the unsprung bit (i.e., the wheel)". I understand that the tight bit of the spring, which is heavier is up, but I didn't understand why is this better, considering that we are always loking to pack the heavier things low as possible?
    Dilbert's Avatar
    Apr 2005
    Staffordshire Moorlands
    You need the softer end at the wheel so it rides easily over bumps, the top tighter bit does not compress at all, it is only when the travel of the spring is much more that it then starts to try and compress the tighter part of the spring.
    if you had the tighter bit at the bottom it has to transmit the small forces of minor bumps through the tight bit of the spring first and this does not work as well.
    Slovenija
    Aaaaaaaa, now I understand! It's all clear now.
    Thanks for the explanation.
    icenian's Avatar
    Jul 2004
    Votadinia
    Quote Originally Posted by Dilbert
    Erm... surely, as far as the spring in concerned, the two ends move closer together, so the coils are compressed, and this will be the same whichever way up it is
    There will be some inertia from the mass of the spring, which will resist movement; and this will be less with the tighter coils at the top as less mass is being moved as the wheel rises/falls; but that's not due to resistance from the compression of the spring.
    I understood that the progressive rate is because the closer wound coils start to bind. I'm not up to explaining this! A quick google turned up this convincing sounding explanation - Jenna will be along in a minute to tell us if it's true or not
    http://www.gti-vr6.net/library/suspe...planation.html
    Take a "simple" 100 lb/in straight-rate spring, composed of 4 identical
    evenly spaced coils. Apply 100# of force. The spring compresses 1".
    Each coils compresses 1/4". Add another 100# and the spring compresses
    and additional 1" (2" total) and each coil is now compressed an
    additional 1/4" (1/2"total). This continues linearly until the coils
    begin to bind (at which point you no longer have a spring). From
    observing this spring, we can deduce that each coil has a rate of 400
    lb/inch.
    What makes a spring progressive is a geometry where some of the coils
    bind up partway through the anticipated travel. For instance let's take
    our original spring and play with the coil spacing. Let's wind it so
    that the first two coils only have 1/4" of air between them while the
    other two coils have substantially more. Put 100# on the spring, it
    compresses 1". But at that point, two of the coils can't compress any
    more. Add another 100# and it only compresses 1/2"; i.e. the rate of
    the spring has doubled to 200 lb/in!
    May 2006
    yep makes no odds which way up to how it works in general, putting the tighter wound end to the top will reduce weight marginally at the wheel but then the weight of the extra coils will compress the lighter ones and to some extent counteract the effect of the progressive nature.... lol bit **** or bust!
    http://www.atvscene.com/video/evalua...6/springs.html
    goes some way to explain the theory.
  1. fork springs
    By T ALP in forum Transalp
    Last Post: 20-02-07, 09:43 AM
  2. Fork Springs
    By Ashley in forum Africa Twin
    Last Post: 10-11-05, 08:45 AM
  3. WP Progressive fork springs
    By Tonyross1 in forum Africa Twin
    Last Post: 09-05-05, 07:31 PM
  4. Progressive springs for front end
    By ghostridergary in forum Africa Twin
    Last Post: 21-12-04, 08:17 PM
