Re: OVERLAND - maintenance program -
Originally Posted by
goodwoodweirdo
Hi folks,
I have a '92 65,000 km RDO4 which is running very well, I've only had the bike for a few months and want to start a maintenance program for a long trip next year. Apart from the obvious what else should I check eg timing chains, bearings, compression maybe, chassis corrosion ? clean and drain the tank. I'll replace the water hoses but don't plan on dismantling the engine for items like oil pump.
Am I right in saying RD04 don't suffer from fuel pump problems?
Is there a common spot for the chassis to crack when overlanding fully loaded ?
Kind regards
Matt
If you are heading off on a big trip next year it gives you plenty of time to get a "feel" for what's right and what needs attention, sure, stuff like C&S, bearings and cables need a thorough check.
I wouldn't touch the motor unless it really need's it.
Don't fix what ain't broke.
'02 Transalp
'01 Transalp (Transrat)
'98 Transalp
'91 NC30
'08 Hornet (Vanessa's)
