Results 1 to 10 of 15
Thread: head gasket & ripoff Honda dealership...
    paulgthomson is offline Member
    Jun 2006
    london
    Aaargh,
    my bike is weeping oil from the cylinder head - only a tiny, tiny bit. NO affect on performance Took it into Motoden in London, they did a pressure test and it was fine up to 100psi apparently so they said no emergency but I would need to replace the gasket at some. They gave me a quote with about £120 for parts (including replacing just about every washer, bolt and gasket from cylinder to exhaust) and £220 labour.
    How hard a job is this? Isn't it just one large gasket? Could be stretching my abilities but f**. I'm feeling a bit too skint for this
    Paul
    mal's Avatar
    mal
    mal is offline Senior Member
    Aug 2004
    GLASGOW
    post
    What cylinder is it? front or rear,engine has to be removed for one of the cylinders,unfortunately can't remember which one.
    If it's the rear cylinder are you sure it's not just the rubber cam cover gasket which is leaking. This costs about 8 quid and can be changed by anyone with a spanner.
    Hagalaz's Avatar
    Hagalaz is offline Member
    May 2006
    North Somerset
    Is it definitely the cylinder head ???, not the rocker cover ?.
    The rocker cover has a rubber gasket : part No 5 on the fiche
    Have a search on the forums, as I seem to remember someone having this gasket weeping after the rocker cover had been off and I have a slight oil trace from the front cylinder rocker cover, but not enough that it need more than a quick wipe with a rag now and again.
    If it is the cylinder head weeping it may not need any more than a quick torque down.
    Every cloud has a silver lining (except for the mushroom shaped ones, which have a lining of Iridium & Strontium 90)
    Jun 2006
    london
    thanks guys,
    I'll take a closer look and if I can't make any sense i'll get my camera out over the weekend and post some pics.
    Have a good weekend!!!
    Paul
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: head gasket & ripoff Honda dealership...
    Quote Originally Posted by paulgthomson
    Aaargh,
    Paul
    If your head gasket really was leaking then chances are your cooling system would be milky from the oil getting in. Unless it was leaking from the cam chain side. See the black outline of the head gasket and its relation to the cylinder when its mated.
    Don't be confused by a leaky valve cover.
    This is what a weeping valve cover gasket looks like after 45.000 miles.
    It's not a big deal unless it becomes a running leak. Is yours a running leak? I cleaned my valve cover gaskets up and reused them.
    IMO a head gasket is either leaking...or its not leaking. If it is leaking and its the front cylinder then you will HAVE to remove the engine from the frame. Rear cylinder can be done in situ on the bike. One job is obviously huge and the other just big.
    samih's Avatar
    samih is offline Senior Member
    Jun 2004
    Co. Kildare, IRL
    He said it was pressure tested, so gotta be the headgasket.
    cabbage2404's Avatar
    cabbage2404 is offline Senior Member
    Jan 2006
    South Wales
    Replaced my rear rocker cover gasket today, ready for the Dartmoor meet . If yours turns out to be the same gasket make sure you replace the o-ring that fits on the rear coolant feed pipe while you are at it.
    GS owner (The Suzuki one, not the Bavarian Monster)
    magwa's Avatar
    UK West Midlands
    Hi there paul,
    From memory it was your rear cylinder but you can change the top gasket very simply yourself first.
    Even if it is the head gasket is not that bad a job. I had to change them on a Honda CX powered kit car and change a crank to boot.
    A lot of 'ROT' is talked about 'Honda Trained mechanics'
    I've prob rebuilt more engines ( all makes ) than most and you don't need to worry to much
    Do the simple job first and see a how it goes
    all the best
    Magwa
    Magwa:
    Given up Adventure Biking
    Magwa can now be found at
    Wingnut's Avatar
    Wingnut is offline Senior Member
    Sep 2009
    Ireland
    Quote Originally Posted by GSPD750 View Post
    Hey man
    How you doing would you have a look at these pics and tell me what you think
    Theres oil at the back of the second engine case and I don't know where its coming from also looks like Ive got a leak in the head gasket but coolant is clear?
    don't fancy ripping this engine my self .
    Jonny
  1. Honda XR cylinder head on a Dominator Engine?
    By enduroman in forum Dominator / FMX
    Last Post: 24-04-08, 09:12 AM
  2. New head gasket
    By Renaz in forum Dominator / FMX
    Last Post: 02-08-06, 07:48 PM
  3. Valve cover gasket (rear) leaking.
    By doglegdon in forum Africa Twin
    Last Post: 10-07-06, 09:43 PM
  4. Any ideas for gasket material?
    By Lord Stig in forum Africa Twin
    Last Post: 07-10-05, 06:18 AM
