Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Carrying Tyre levers - A solution!!
    Ralph's Avatar
    Ralph is offline Senior Member
    Sep 2006
    West Yorkshire
    After pondering where to stash tyre levers on the AT i found a simple solution :idea:
    A pair of 15" tyre levers fit perfectly to the underside of the seat!
    [img][/img]
    It's such an obvious place i am sure it's an old idea, however i didnt find anything on the forum.
    For those interested, i cut a notch out of the ridge to allow the levers to fit flush to the under side of the seat. This is only minor surgery with a mini hack saw and does not effect the strength of the seat in any way. A neat cut exactly the width of the levers side by side helps to keep them in place. The levers are then slotted under the existing rubber strap.
    [img][/img]
    A small cut is also required where the levers pass over the rim of the tool compartment to allow the seat to sit back down in it's original position.
    The levers i use are mm perfect and the curved ends follow the contour of the seat so they almost like part of the original tool kit. If they were any longer they would stop the latch end of the seat clicking into place.
    [img][/img]
    I have not hit the trail yet but i doubt they will move around. If they do i will find a short rubber strap for the other end of the levers and hook each end into the round holes in the seat base.
    Sorted
    jabba's Avatar
    Wehay there spot on have exectly the same levers bit fiddly sometimes to put the seat on though
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: Carrying Tyre levers - A solution!!
    Quote Originally Posted by Ralph
    Nice job. Your post and pics just gave me an idea and more room in my panniers. I typically use three irons to get the job done though.
    Whealie's Avatar
    Whealie is online now Wing Commander
    Lewisham, SE London
    mine are cacble-tied to the frame under the side panel - you can get at them (and the spare tubes tied there too) without removing anything else.
    loftyjohn is offline Member
    Mar 2006
    Cannock,Staffs
    Bl**dy good Idea
    Have you any experience of changing a tyre on the road side??
    Waiting for the AA on weekend is a waste of space
    Whealie's Avatar
    Lewisham, SE London
    Nope but I have had experience of waiting for the AA.
    there's loads off threads about changing tubes and removing tyres etc. I'm hoping I will be with someone who has done it when it happens (even if only to use their side stand to break the bead) but I'll just have a bloody go at it if not.
    Ralph's Avatar
    Sep 2006
    West Yorkshire
    Quote Originally Posted by loftyjohn
    Bl**dy good Idea
    The levers are a last resort. I carry a small tin of Holts tyre weld in the tool compartment which i would try first. If this failed then a spare front inner tube could also be also used in the rear tyre to get me home. (Never tried this but i believe it works).
    I also have a third short tyre lever which fits vertical in the tool box to make the job easier as GSPD750 mentioned. I just need to get one of those small hand pumps.
    I've only ever done roadside punchure repairs before with someone elses help. We had loads to do during a 6 month trips across Africa.
    I don't fancy the though of doing it on my own in the dark on a cold wet wintery night!
    Sharribee's Avatar
    Sharribee is offline Matron
    Jan 2006
    Wales
    I would have no idea what to do with a tyre lever, I do carry the tyre foam stuff but again doubt I would know what to do with it
    Call the RAC then my dad cause he will always come and rescue me
    DELILAH
    2010 F800 GS
    DaveS's Avatar
    Nov 2003
    Bristol, UK.
    Well done Ralph.
    Someone did post some pics a long time back with the levers in exactly that spot. Can't remember who though!
    Forum help and advice needed?
    2010 KTM 450 EXC-R
    Follow xrv.org.uk on Twitter.
    doglegdon's Avatar
    Southern Philippines
    Quote Originally Posted by Mabel
    Wot type of foam? I'm considering buying some for real emergencies(if I can find here), so at least I can get to a road side vulcanizing shop, of which we have many over here. Has anyone tried "SLIME", the emergency tyre sealant? Any success?
    2008 KTM 990 Adventure S
  1. Tyre Levers
    By DaveS in forum Wheels, Tyres & Tubes
    Last Post: 02-05-07, 02:09 PM
  2. tyre irons...ahhh hem....levers
    By Xander in forum Wheels, Tyres & Tubes
    Last Post: 21-02-07, 02:12 PM
  3. Solution to the BMW problem...
    By iswoolley in forum Other Bikes
    Last Post: 12-01-07, 12:09 PM
  4. Final solution for tripmaster problems.
    Last Post: 29-08-06, 10:23 PM
  5. Tyre Levers
    By miggy in forum Africa Twin
    Last Post: 15-03-06, 08:15 AM
