If you can turn it this is a good sign. Get someone to turn it as you belt the other end with gusto. Once the end of the axle is flush with the swingarm, use a socket set extension bar to carry on the good work (hit the end with the hammer whilst holding it on the end of the axle) if it won't pull free with your hand (support the weight of the wheel with some bricks under the tyre so it doesn't twist and hold onto the axle.)
