A trick I used to use on my kickstart DR350 (a notoriously bad starter when not run for a few months) was to open the drain screw on the float bowl a little, turn the fuel on and let the old stuff drain out, pulling freshers stuff from the tank. Used to turn a 400 kick start into a 4 or 5 kick start. The screws will be at the lowest point on the floatbowl.
