Results 1 to 4 of 4
Thread: Clutch cable question
    barftone's Avatar
    Apr 2005
    Bath, England
    Question for the high mileage AT owners (Maverick??). How long is the clutch cable going to last me? I strip and grease the levers and lube the cable normally once a year. Being a bit sad I normally replace high wear items before they let me down.
    magwa's Avatar
    UK West Midlands
    Mine went ( not quite but I noticed it on service just before it snapped)
    at 33,000miles original cable! ( 11yrs old)
    £9.50 later and 20mins new cable fitted Gen Honda part.....heres to the next 33k
    Magwa
    Magwa:
    Given up Adventure Biking
    Magwa can now be found at
    Mutley's Avatar
    May 2004
    Top of the hill
    clutch cable
    Probably quite a hard question to answer barftone as not everyone even uses the clutch upshifting, and some will slip it continuously offroad.
    The main thing to watch for is the angle that the cable comes out of the outer cable at the bottom. If the bracket is out of line, it forces the inner cable to rub on the outer and eventually wear prematurely. Just look at the bottom of the cable while you pull the clutch lever in a couple of times and you'll soon see if it looks straight. If it's not in line, just 'help' it back into position with a moveable spanner.
    Pussyhorse's Avatar
    Pussyhorse is online now Senior Member
    Essex mate
    Mine seized at 112,000 km.
    Get a honda one if you're planning on keeping the bike for ages.
  1. Clutch Cable
    By SteveLee in forum Africa Twin
    Last Post: 07-09-07, 08:38 AM
  2. Clutch cable lubing
    Last Post: 28-11-06, 03:45 PM
  3. clutch cable problems
    By dominatormike in forum Dominator / FMX
    Last Post: 01-08-06, 06:10 PM
  4. Clutch Cable!
    By Simon in forum Chatter
    Last Post: 18-05-06, 11:24 AM
  5. Clutch Cable
    By Paul P in forum Africa Twin
    Last Post: 25-02-06, 08:28 PM
