Results 1 to 10 of 33
Thread: No power
    5135jimmy is offline Junior Member
    Nov 2006
    Scottish Borders
    No power
    Hi everyone I'm new to Africa Twins and new to the site. I purchased my first africa twin 2000 miles ago and use it to commute on a daily basis. It is an RD04 1991 XRV750. The bike has recently let me down. It seems to be missing and will not exceed 70mph or 6,500rpm and feels gutless. It has been fine until now and this fault has just started. I thought I would change the plugs and discovered it has 4. I have changed the easy ones in each cylinder but cannot seem to get a plug spanner down far enough into head. Anyone any ideas firstly what the fault could be and secondly advise on a good plug wrench to reach into heads. Many thanks in advance.
    Jimmy
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    The spanner in the bike's tool kit is the only one I've found suitable.
    Ref. fault - have you checked the air filter? Carbs balanced? Fuel supply? Dirty Carbs? Carb inlet rubbers loose/split? Airbox sealing on carbs?
    Nov 2006
    Scottish Borders
    I haven't but I will.
    Many thanks
    mal's Avatar
    mal
    mal is offline Senior Member
    Aug 2004
    GLASGOW
    post
    If you don't have the spanner , Wemoto sell it for about £10 www.wemoto.com
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Jimmy
    Nothing on earth will get that plug out except the original sparkplug tool OR an aftermarket one that has been time consumingly modified.
    Mal has given excellent advice, buy one from WeMoto (in Brighton) and it'll be the best £10 you've spent.
    With regard to your problem, I'm not convinced it'll be the plugs, so I would chech the following in addition.
    1. CHOKE; THE MOST COMMON @ bad running culprit. Chances are, you think it's OK, but check the cable, splitted, and individual cables running to each carb. The problem is the cables bind and keep the choke on.
    2. FUEL PUMP; Check that it is actually pumping fuel. Some are notoriously troublesome. Also check that there is power to it.
    3. FUEL FILTER; Is it clean, is fuel flowing through it cleanly.
    4. CARB DIAPHRAGMS; One or both of these could be damaged, but I'd check these last, as you could damage them just checking them. If it is these, OE parts are horrendously expensive, so you could try these people.
    http://www.nrp-carbs.co.uk/
    5. CDI unit; It may be faulty, or the coils not receiving a good signal due to bad connections.
    6. COILS; Check the connections. Check (with a spare plug earthed against the frame) that they are making a spark.
    Good Luck
    Whealie's Avatar
    Lewisham, SE London
    What colour were the plugs you did remove?
    If they were at all sooty it is likely to be your choke - remove the bable completely and free it up.
    Nov 2006
    Scottish Borders
    thanks
    Hi
    Thanks for the help everyone. Ive made a start on it. Got the carbs stripped off it today so will give them a good looking over.
    Simon Guest
    Quote Originally Posted by Whealie
    Whats a "bable"?
    stageonesimmo's Avatar
    Nov 2006
    A fish you stick in your ear to translate gobeldy-gook...........
    I'm with the plug condition question on this one - it shows up a variety of evils and is always a good place to start - how were they? The picture in a petrol engined car Haynes Manual is an excellent guide to how they should look and the causes of many of the problems if you have one around it's worth a look......
    Nov 2006
    Scottish Borders
    plugs
    Still have not managed to get plugs out yet till spanner arrives but got the easy ones out. The rear cylinder one was quite grey and dry and the rear cylinder quite blackand oily but not overly so. Strange????
  1. The Twins got the power now
    By MollyandMitch in forum Africa Twin
    Last Post: 24-02-07, 11:45 AM
  2. K & N power filters
    By dick500 in forum Africa Twin
    Last Post: 04-07-06, 07:55 AM
  3. power
    By kenty in forum Africa Twin
    Last Post: 06-01-06, 01:17 PM
  4. Power reduction
    By icarus in forum Africa Twin
    Last Post: 06-12-05, 08:24 AM
