Results 1 to 7 of 7
Thread: Rear wheel rebuild
    mal's Avatar
    mal
    mal is offline Senior Member
    Aug 2004
    GLASGOW
    Rear wheel rebuild
    I am going to get my rear wheel re-built, Central wheel don't make a 2.75 x17 (original fitment) they can however rebuild using a 2.50 x17 or 3.00x17 rim, which one should i go for?,i will be using the original tyre size 140/80/17 ,i am worried if i go up to a 3.00X17 it may rub on the swinging arm.
    magwa's Avatar
    UK West Midlands
    3.00 x 17 should fit
    NO PROBLEM
    That equates to about one eigth of an inch (2.5 to 3mm) extra width each side....take a look at the gap now.... you will see it should fit
    Good Luck
    Magwa
    Magwa:
    Given up Adventure Biking
    Magwa can now be found at
    anton88's Avatar
    I recently had new rims/wheels built by hagon in Essex - the only rim width they could offer me was 2.50 rather than the original size of (2.75) - still works ok and managed to squeeze on a standard size 140 width TKC 80 tyre - was a bit tight tho.
    z-weiser's Avatar
    z-weiser is offline Now a transalper
    Manchester
    wjhats it cost for a new rear wheel these days?
    Slimie is offline Huh?
    Devon, proper job!!
    Anybody ever gone for an 18 inch rim?
    Great choice of off road rubber?
    -Simon
    mal's Avatar
    mal
    Aug 2004
    GLASGOW
    post
    Thanks for the reply's, approx cost of re-build is about £200 per wheel, it depends on type of spokes etc.
    Jim Rowley's Avatar
    Jim Rowley is offline Member
    Colorado Springs, CO
    Quote Originally Posted by Slimie
    -Simon
    I did.
    Jim.
  1. Rear wheel out for new rim.......
    Last Post: 24-09-08, 10:43 PM
  2. front & rear suspension rebuild
    By cookiemonster in forum Dominator / FMX
    Last Post: 25-12-06, 11:52 AM
  3. 650 TA Rear wheel on 600??
    By ger in forum Transalp
    Last Post: 10-07-06, 11:38 AM
  4. Rear shock rebuild?
    By Bigsteveo in forum Africa Twin
    Last Post: 11-04-06, 12:24 PM
  5. Rear Wheel
    By in forum Africa Twin
    Last Post: 01-01-70, 12:27 AM
