Since getting a set of Zega boxes for Christmas, I figured I should get around to putting the pannier frames onto the @.
When I had them on last time I seem to remember that it isn't possible to remove the side panels from the bike with the pannier frames in place.
Is this correct or have I just not mounted them correctly![]()
It will be a real pain if this is the case, as I have my scottoiler resovoir under the left hand panel (which needs refilling every once in a while)![]()
Has anyone else come across this? And if so, is there a workaround or 'special' way of removing side panels, when the pannier frames are fixed?
