Originally Posted by
Lord Stig
Got round to lubing my cables yesterday and decided to follow Yen's advice - sure enough it runs far better without the insert, although it's possible to feel the cable running over the bar and casting. Worth it though, so thanks for that Yen (plus for the fact I don't have to go through the hassle of getting the casings together with the cable inners running properly.
On the downside I discovered water in the choke cables/on the plungers and the start of corrosion - they still don't seem to run properly (though I never use them, just connecting the lever can activate them leading to one being stuck if it's so inclined). I'll be disconnecting the cable next - also Yen's advice.
Stig
I'm starting to believe that the choke lever should have a little glass box around it and a small toffee hammer attached on a chain. Underneath should be a note in about 5 languages.
'Warning, in extreme cold, use hammer to break glass and activate choke lever. Honda accepts no liability if doing so ruins the rest of your ride when the bike reaches running temperature.'
1 Varadero/34,000 miles ridden (of 57,000 miles on the bike), it's all still new to me!
