Hi...would go along with everything said so far....the AT weak points are Choke cable/springs, Fuel pump & Rectifier...all easily fixable (subject to parts availability)...so my advice would be grab them here and take them with you counting the cost (£150ish) as part of the purchase price!
The AT it is quite heavy...great for dirt roads, but not really for anything more technical.
I'm 6'2" and its fine but if you want more ground clearance you can get a jack up kit from Africa Queens for about £240!!!...you will have to modify the side stand though.
01 XRV750 Africa Twin. RWB
Dynojet+Airbox Mods, Heated Grips, Scottoiler, MRA Varioscreen, Motad Desert Bars, Autocom Kit6, Garmin Zumo 400, Kenwood B2B, Mitchelin Anakees.
