Hi All,
Brakes again, I'm afraid. Not the front for a change - although
I did just change all the pistons and seals on those - but the rear.
The rear brake on my '91 AT is less than happy. One of the
"slider pins" (I think they are called) is seized solid in the bracket.
It's the allen (alan? Alen?) bolt circled in red in this photo:
http://web.rodentia.org.uk/brake
As I expect a lot of you know, the hex-head bolt (circled in blue) is
threaded at the end and smooth near the "head" of the bolt, and
screws into the bracket. That one is fine - came out no trouble.
The other one is the other way round - smooth at the "far end" but
threaded near the head of the bolt - it's supposed to screw into the
calliper and just sit in the bracket, allowing the sliding calliper to
do it's thang.
It's don't, unfortunately.
Now, we've tried everything we could to get it out, but with no
luck. I've got a bolt/pin thing on order, and it looks like we might have
to drill it out.
However, as that might well bugger up the bracket, I've been
looking around for a replacement (since a new one from a dealer
is 90 quid!)
I've found this on ebay:
http://tinyurl.com/2dhh4r
Which seems good, assuming that it isn't also seized, but it's
listed as being for "95-01" bikes, and mine is '91. Now, in the
photo it looks exactly identical - but I wanted to ask the massed
ranks on here if they know otherwise!
So, that's it, really - is the rear brake mounting bracket different
for different models, or did it stay the same?
Also, as a side note, has anyone brought anything from "e-breakers"
aka http://www.m1salvageandbreakers.co.uk ? Ok or one to
avoid ?
Cheers in advance.
