New AT owner! Rebuild, photo alert!
Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 65
Thread: New AT owner! Rebuild, photo alert!
    Dec 2016
    Netherlands
    I finally found me an Africa Twin! Two months ago I bought this 1996 RD07A model Twin, it's not the best looking bike as it is a bit worn, rusty and tired. I'm now busy with a full rebuild and i'm hoping to drive it again in the spring of 2017. I started with the rebuild a month ago so thats why the tons of photos.
    Cockpitframe with complete wire loom, needs some repairs.
    Found a burned voltage regulator/alternator plug
    Broken crashbars, will be welded and painted.
    Removing the engine
    Bare frame
    Starting with the engine. To mission is painting the engine, replacing the countershaft, and checking all the parts for condition and cleanliness.
    Starter clutch still ok.
    Removing the camshafts, gears, clutch, gear shift mechanism, oil pump. Next step is splitting the engine cases.
    Camshaft chains
    Removing the valves from the heads
    Exhaust valve not looking good (white marks from fuel seeping through during leak test)
    Both exhaust valves
    Intake valves and guides looking good
    Front cil exhaust valve, allready lapped this valve a bit
    Rear exhaust valve not looking very good
    Lapped the valves and seats. Installed valves and leak checked with fuel in the head, still full after aprox 6 hours.
    Splitted the engine to replace the countershaft and bearing.
    Crankshaft bearings
    Replacing the countershaft
    What does this code mean?
    Some smudge on the oil pump filter, seems normal as compared with other rebuilds.
    Much better
    Rebuilding the engine
    Manually checking the gears, offcourse did this before installing the heads.
    All bolts, nuts, springs, tools, rings etc etc have been plated by GTO Plating in Veenendaal.
    Sorting it all out, fun job
    Rebuilding the starter motor
    Prepped the frame and swingarm and dropped it off with some other loose parts at Waayenberg Coatings in Barneveld. Should be finished after new years.
    Upgraded the cockpit with a oil press meter and a over- and under voltage warning light from eBay. It's green when voltage is normal and will flash more red and faster when the voltage becomes higher or lower than the max allowed minimums. Also gave the cockpit a good cleanup.
    The warning light will look like this
    The thingy on the left is a USB charger with voltmeter
    Rebuilded the front forks with new seals, bushings and 10W oil .
    Planning to buy a jack-up kit from Kitped
    Also started with the rims. Fortunately not much corrosion, just a small spot around the tire valve hole wich I reworked
    Sanded down
    Small spots seem to look like corrosion
    Professionally build stand to paint the rims
    Will be polished
    Rebuild the battery tray
  2. The Following 11 Users Say Thank You to Turbinerepair For This Useful Post:
    at750nh1e (02-02-17), een705 (03-01-17), Farcall (04-01-17), Geldof (02-01-17), grbeiz (01-02-17), GSPD750 (02-01-17), MIKETHEBIKE (28-03-17), Paul-S (03-01-17), Rip Fox (18-01-17), SamuraiZack (16-01-17), TopBuzz99 (07-01-17)
  3. Remove Advertisements
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: New AT owner! Rebuild, photo alert!
    Looking great.
    I wish I had the workshop facilities you have I'm currently rebuilding my old RD04 in the hallway of my house!!
    http://ukrp.musicradio.com/gold/live
  5. #3
    Jammytask's Avatar
    Jammytask is offline Senior Member
    Feb 2013
    Central France
    You're making a great job of that so far, keep the pictures coming.
    Chris
  6. Remove Advertisements
    thetimkirby is offline Senior Member
    Dec 2008
    Anglesey and NZ
    Looking great.
    Yeah, but you've got carpet and central heating in your workshop. And I bet it's not far to the fridge...
  8. #5
    iainb's Avatar
    iainb is offline Senior Member
    Apr 2016
    tramore , ireland
    fantastic that is some great work.. really enjoying the thread and happy new year!!!
  9. #6
    Dec 2016
    Netherlands
    Thanks guys! It's a fun job so that makes it much easier.
    On the last day of 2016 I polished the sideplates of the bashplate. I still have to polish the middle plate.
  10. #7
    Traveller's Avatar
    Traveller is offline Senior Member
    Nov 2008
    Derby
    That's going to be one great bike when it's finished.
    RWB XRV 750
    Red XRV 750
    BlackXRV 750
    HRC Colours Honda FTR 223
    GL 1800
    Yellow Honda Trail 90 - CT90 no 1
    Red Honda Trail 90 - CT90
    Red Honda Trail 110 - CT110 Special
    Yellow Honda Trail 90 - CT90 no 2
    Horses for courses
  11. #8
    Jeff Kirby's Avatar
    Jeff Kirby is offline Senior Member
    Nov 2006
    Mapledurwell, Hampshire
    Great photos, what did you paint the engine cases and forks with?
    2000 - VTR SP1
    2003 - XRV750
    2003 - XR400
  12. #9
    Machiru's Avatar
    Machiru is offline Senior Member
    Jun 2013
    liverpool
    Great work there keep it coming thanks
    Sent from my GT-I9195I using Tapatalk
  13. #10
    Dec 2016
    Netherlands
    Quote Originally Posted by Jeff Kirby View Post
    Hi, I used VHT paint, supposed to be heat resistant and designed for NASA . A bit overdone for the forks, but I heard this paint is tougher than normal paint. I had to bake the forks, pizza tasted a bit weird . Engine paint will be 'baked' when the it is running (if it will ever run ).
  14. The Following User Says Thank You to Turbinerepair For This Useful Post:
    fizzy nick (22-01-17)
  1. Wimp Alert !!!
    By Wee Jack in forum Chatter
    Last Post: 02-09-09, 01:36 PM
  2. Numpty Alert!!!
    By 1gear1brake in forum Africa Twin
    Last Post: 24-12-08, 02:55 PM
  3. SALT ALERT
    By romeo one in forum Chatter
    Last Post: 06-11-06, 07:41 PM
  4. NEWBIE ALERT!!!!!!!!!!!!!!!!!!!!!!!!!!
    By reefer in forum Dominator / FMX
    Last Post: 24-10-06, 08:23 PM
