Results 1 to 10 of 12
Thread: Rd 07 vs Rd 04
    koks is offline Member
    london
    Rd 07 vs Rd 04
    Is there big difference between those 2 bikes? I know carbs are differ (takes dieffer air filter) and apparently rd07 got lower seat. any other differences? is much better rd07? I've got transalp at the moment which I don't want to sale it and thinking to get africa
    anton88's Avatar
    RDO4 gains extra points just for being cool
    boboneleg's Avatar
    boboneleg is online now Senior Member
    Bristol
    Quote Originally Posted by anton88
    what Anton said plus different frame, tank, air-box, plastics etc etc
    2003 Transalp
    2004 KTM 950 ADV
    1998 Suzuki DR350
    raigo's Avatar
    raigo is offline Member
    May 2006
    Estonia
    RD07 has pussymagnet
    anton88's Avatar
    Quote Originally Posted by raigo
    chronyx's Avatar
    Surrey, UK
    My one must need replacing then.
    Slimie is offline Huh?
    Devon, proper job!!
    I thnk mine must be worn out too. Or it never worked from day one
    Devon, proper job!!
    Although the fleabag we call "Molly" is strangely attracted to my AT
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    Well, I've owned both and covered over 10,000 miles on both models so reckon I'd give my opinion.
    The RD04 is a more offroad focussed bike, it has the better suspension set up adjustable front and rear damping. It also has more presence, more in common with the RD03, a real rally replica bike.
    Both bikes ride much the same on road and there's not a lot between them. I found the RD04 was the quicker of the two and that's not just one individual bike, I've had a few!
    My personal opinion, the RD04 is the Daddy!
    mladen is offline Member
    Slovenija
    My personal opinoin is for the RD07, because is newer, you can find a lot of aftermaket accessories (for example, Touratech make accessories only for the RD07), lower center of gravity, lower sit, more spare parts, because it was on the market for 10 years, and the air filter is located on the top of the tank, which is very OK if you drive in the sand.
    But it is true that RD04 is better build. You can see that at the first look.
    Over the years of asking opinions to other people which motorcycle is better to buy, I learned that you should buy the one, which you like most. Just listen to yourself, you probably know which one is the one for you.
