Backlash in the BRIDGE COMP FORK TOP. - Page 4
Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 37 of 37
Thread: Backlash in the BRIDGE COMP FORK TOP.
  1. #31
    Massive Lee's Avatar
    Massive Lee is online now Senior Member
    Sep 2014
    Montreal
    Re: Backlash in the BRIDGE COMP FORK TOP.
    I have fitted mine but never tested them as the bike is still in full resto mode. But the goal of this design is to eliminate 100% any possible movement of the handle bar, whatever the conditions. The bushings are machined from Delrin and they are as stiff as aluminum. Basically, it is like solid mounting your handlebar. I initially thought I would make them from urethane, but changed my mind as urethane still has some compliance.
    Some people will say that solid mounting the handlebar will allow vibrations to reach it. It is possible. But my BMW R1150GSA, which is know to vibrate quite a lot above 5,000rpm, has solid mounted handlebars, and it never bothered me.
    I was fed-up with the handlebar getting crooked everytime the bike would drop as well as the lack of precision in twisties. Hopefully the problem is solved now, without introducing too much vibes.
    Lee
    1982 Honda 500 Ascot FT / 1986 Honda 750 Nighthawk S / 1988 Honda 1000 Hurricane / 1990 Honda CBR1000F / 2006 BMW R1150 GSA SE
    2001 BMW K1200RS aka Good Girl -- Current
    1988
    Honda Africa Twin
    akaQueen of Sheeba -- Current
    1996 Honda Africa Twin
    akaGertrude Bell -- Current
    http://www.facebook.com/Massive-Ride-1153740581384956/
    Sep 2014
    Montreal
    @ Chesper
    When you install the handle bars, don't forget to reinstall the upper cup and the thick lower washer. They take up space and are needed.
    1988
    Honda Africa Twin
  4. #33
    chesper's Avatar
    chesper is offline Junior Member
    Jan 2017
    sweden
    Quote Originally Posted by Massive Lee View Post
    @ Chesper
    Obvious. Looks to sit absolutely fantastic. Was a real ordeal to mount of the old, however.
  5. Remove Advertisements
    chesper's Avatar
    Jan 2017
    sweden
    was out and tested affen now after service and overhaul. can only say that the bushings are fantastic handlebar is 100% and actually think vibbratonerna is significantly less than the original.
    thank you very much, Massive Lee, you
    are an amazing man =)
    Skickat från min SM-G388F via Tapatalk
  7. #35
    Dec 2016
    Netherlands
    Sounds nice. I'm getting pretty anoyed by the play in the handlebar. You don't have a set bushings left?
  8. #36
    Sep 2014
    Montreal
    Quote Originally Posted by chesper View Post
    I am so glad the problem was solved. If you look at older big mono Hondas, the handle bars were mounted solid too. So, why fitting handlebar rubber bushings on a bike that runs even more smoothly than a big thumper? Well, that was my reasoning and it seems it works.
    Glad I was of help.
    Lee
    Quote Originally Posted by Turbinerepair View Post
    I have two or three sets left. $60.00cad + $13.00 shipping by Air without tracking
    $60.00cad is my cost on these. Making small batches of precision parts is costly. I am sure I can lower my prices if I can have 100 sets made
    1988
    Honda Africa Twin
  9. #37
    Dec 2016
    Netherlands
    That sure is costly Lee, but I can imagine it's expensive to make these kind of specific parts. I'll let you know, have to weigh the pro's and con's you know .
    RD07A '96, RSV Mille '02, ZXR750H1. Previous: ZX9R '94, '98 & '03, 1150GSA '03, ZX10R '04, ZXR750J2, RSV Mille R HAGA '03, GPZ750 '87, VFR750 '86.
  1. Fork top cap cross threaded! 1989 600 transalp
    By Brighton Russell in forum Transalp
    Last Post: 04-05-16, 08:33 PM
  2. Fork top spring
    By olionel in forum Africa Twin
    Last Post: 19-07-11, 10:13 AM
  3. Replies: 3
    Last Post: 05-02-11, 09:09 AM
  4. Honda cr250r red rocket 78/79 top yoke( top fork clamp)
    By Admin in forum eBay - CR/CRF/CRM
    Last Post: 17-01-11, 04:40 PM
  5. Wanted: Africa Twin Front Fork Top Caps
    By AlanH in forum For Sale / Wanted
    Last Post: 12-07-08, 11:17 AM
