Results 1 to 8 of 8
Thread: Production AT vs the racing one
    chronyx's Avatar
    Surrey, UK
    How similar is the AT we own to those used in desert races etc?
    Could you actually use a production AT in the same way?
    May 2006
    marathon bikes are very loosely based on production, works bikes are totally different whatever the press department tells you!!...
    personally i would be very worried if i rode a production bike on any event with out quit a few upgrades, no production AT would last a raid in stock form thats for sure (with the obvious exception of the RD03 Marathon), as far eligatibility then it would only be allowed in the open and modified class on most raids as the ceiling is normally 450cc for stock and FIm.
    Events Like the Dakar although run under FIa and FIm rules the classes are not regulated so to some extent you can do what you want as long as the bike/car/truck complies to the safety and build regs... more information on these is available in the FIA constuctors book.
    Technical List N°01 Fuel tank materials homologated on the basis of FT3-1999, FT3.5-1999 and FT5-1999, as well as FT3 and FT5 standards - updated: 07.02.2007
    Technical List N°02 Fuel analysis laboratories recognised by the FIA - updated: 01.01.2007
    Technical List N°03 Manufacturers of flow-meters and models homologated by the FIA - updated: 01.2003
    Technical List N°04 Testing centres for crash-test recognised by the FIA - updated: 15.09.2005
    Technical List N°05 Connectors for taking fuel samples - updated: 15.01.2007
    Technical List N°06 AFFF extinguishing products approved by the FIA - updated: 01.2003
    Technical List N°07 Repair facilities approved by the F3 and F3000 manufacturers - updated: 01.2003
    Technical List N°08 Catalytic Converters homologated by the ASNs - updated: 15.08.2006
    Technical List N°09 Catalytic converters homologated by the FIA (Class 1)
    Technical List N°10 FIA Approved Test Houses for Competition Seats according to FIA standard 8855-1999 - updated: 23.09.2005
    Technical List N°11 Formula 3 approved safety structures - updated: 01.2003
    Technical List N°12 Seats homologated on the basis of the FIA Standard 8855-1999 - updated: 12.02.2007
    Technical List N°14 FIA Approved Test Houses for Fuel Tanks according to FIA standards FT3-1999, FT3.5-1999 and FT5-1999 - updated: 19.01.2006
    Technical List N°15 FIA Approved Test Houses for Extinguisher Systems - updated: 11.04.2005
    Technical List N°16 Extinguisher systems homologated by the FIA (see also Bulletin November 2002) - updated: 22.05.2006
    Technical List N°17 Headrest materials specified by the FIA - updated: 08.09.2004
    Technical List N°18 List of manufacturers of non-return valves and models homologated by the FIA - updated: 15.10.2003
    Technical List N°19 List of manufacturers of lights for rain homologated by the FIA - updated: 18.08.2006
    Technical List N°20 Energy absorbing inserts for Formula One tyre barriers complying with the standard FIA 8861-2000 - updated: 13.02.2006
    Technical List N°21 FIA Approved Test Houses for Protective Clothing for automobile drivers according to FIA standard 8856-2000 - updated: 17.03.2006
    Technical List N°22 FIA Approved Test Houses for Safety Harnesses according to the FIA Standards 8853/98 and 8854/98 - updated: 08.09.2004
    Technical List N°23 Roll Cage Padding Homologated by the FIA - updated: 01.01.2007
    Technical List N°24 Harnesses Homologated by the FIA according to the FIA Standards 8853/98 and 8854/98 - updated: 07.02.2007
    Technical List N°25 Recognised Standards for Helmets - updated: 06.10.2005
    Technical List N°26 Anti-Skid Paints for Track Marking (FIM Standard) - updated: 08.09.2004
    Technical List N°27 Protective Clothing for Automobile Drivers Homologated according to the FIA Standard 8856-2000 - updated: 05.02.2007
    Technical List N°28 Material for the upper surface of the hans-yoke in contact with the shoulder straps - updated: 24.12.2004
    Technical List N°29 List of FIA approved HANS Systems according to FIA Standard 8858-2002 - updated: 12.02.2007
    Technical List N°30 FIA Approved Test Houses for HANS systems and compatible helmets according to FIA standard 8858-2002 - updated: 17.02.2006
    Technical List N°31 List of FIA approved Extrication systems - updated: 08.09.2004
    Technical List N°32 FIA Approved Test Houses for Helmets according to FIA standard 8860-2004 - updated: 08.09.2004
    Technical List N°33 List of FIA Approved Helmets according to FIA Standard 8860-2004 - updated: 21.06.2006
    Technical List N°34 FIA Approved Test Houses for Gloves according to FIA standard 8856-2000 - update: 08.09.2004
    Technical List N°35 Companies Approved by the FIA for the calculation of Safety Rollcages - updated: 13.07.2006
    Technical List N°36 List of FIA Approved Head Restraint - updated: 03.11.2004
    Technical List N°37 List of cables in compliance with the FIA standard for Formula One wheel restraint cables & list of test houses approved by the FIA - updated: 09.02.2006
    bet you wished you never asked now!!!
    the FIM list for bikes is similar but i dont have it on file.
    Chad's Avatar
    wickford,essex
    sheeeeeat jenna you da girl
    GeoBloke's Avatar
    GeoBloke is offline Senior Member
    Oct 2005
    Stroud, Gloucestershire
    Just saw this thread and Jenna, words fail me.
    At least I learned a new term today. Something like "homologation" doesn't pop up much in normal conversation but now I'm going to try and work it in somehow.
    Quote Originally Posted by GeoBloke
    Isn't that a crowd of gay fellas?
    Robster's Avatar
    Feb 2005
    Shepperton
    Quote Originally Posted by YEN_POWELL
    Oooh you beat me to that one!
    I'm slipping, must be my age!
    GeoBloke's Avatar
    Oct 2005
    I should have seen that one coming.
    Chad's Avatar
    wickford,essex
    shame on you rob to let and old hand like yen beat you to that
  1. Racing Varadero
    By samwise in forum Chatter
    Last Post: 13-02-07, 04:50 PM
  2. BioEthanol TransAlp Racing??
    By Mudwiz in forum Mechanical Advice
    Last Post: 04-01-07, 06:49 PM
