Results 1 to 10 of 11
Thread: Handlebar Risers
    Hagrid's Avatar
    Hagrid is offline It's Just A Ride....
    Sep 2006
    South Coast
    Handlebar Risers
    Thinking about purchasing some Handlebar Risers from Touratech... (I don't like their new Web Site!) Here...
    Anyways, Quick Q. if I may... Will I need to change any of the cables etc. after fitting or will the originals stretch far enough?
    Thanx All
    Xander's Avatar
    Jul 2006
    Lichfield
    you have about 25mm of play in your cables... so you can get a way with about that much of a riser.. any more and you will have to change your cables, the wires should not be much of an issue unless you go silly high
    barryw33's Avatar
    barryw33 is offline All the gear...no idea
    Sep 2006
    Malaga, Spain
    i have a set of 25mm SW Motech risers for sale if you are intrested, you dont need to change cables with 25mm ones. 20quid and a couple of quid for postage if you want them
    samih's Avatar
    samih is offline Senior Member
    Jun 2004
    Co. Kildare, IRL
    I have those SW-motech risers and they are good quality and don't need other mods apart from releasing one of the brake hose clamps to create more clearance.
    Maverick's Avatar
    May 2004
    Tilbury, Essex
    Re: Handlebar Risers
    Chad gave me a set of Nippy Norman's handlebar risers that not only goes up 25mm but also back which release a fair amount of stress on your shoulders
    willb is offline Senior Member
    Cambridge
    I've got 35mm on mine, but the brake leads had already been changed, and they make long rides more comfortable.
    BMW F800GS, Touratech Panniers, Givi Topbox, Scott Oiler, Metal Mule screen
    Used to have:RD07, 2001, Touratech Panniers, Nonfango topbox, baglux tank harness, Scott Oiler
    Hagrid's Avatar
    Sep 2006
    South Coast
    Quote Originally Posted by barryw33 View Post
    Thanx Barry... If I go down this route ill let you know
    KTiM's Avatar
    KTiM is offline Senior Member
    Jan 2006
    Guernsey, Channel Islands, UK
    I'll 'ave 'em!
    will's Avatar
    will is offline Senior Member
    glos
    Like the sound of the nippy normans where can you get them thanks Will
    KTiM's Avatar
    Jan 2006
  1. Bar Risers
    By dazzerrtw in forum XR
    Last Post: 23-08-07, 10:37 PM
  2. Handlebar Risers
    By markw in forum Transalp
    Last Post: 12-11-06, 03:56 PM
  3. Handlebar Risers
    By lootch67 in forum Africa Twin
    Last Post: 24-10-05, 07:26 PM
  4. Handlebar risers for 99 @
    Last Post: 17-10-04, 06:33 PM
