Re: Front brake caliper pin removal
Originally Posted by
richardb
Anybody got any good tips?
The pin that holds the pads in is well and truly stuck. The hex shape is rounded out, I've tried getting another sixe up allen key in there, but to no avail.
Also tried drilling a pilot hole and using a screw/bolt removal tool, but I just can't get the thing to grip - is there a trick to this?
ANy other ideas appreciated or I will be going tail between my legs to my nearest garage.
Only saving grace is I've probably got a couple of weeks left in the pads - but I hate to cut it too fine.
thanks
You can try a torx bit hammered in and an impact driver, or remove the caliper and grip the inside part of the pin with molegrips, or use a hot rag around the alloy for a few minutes before trying to undo the pin.
