headlights
Results 1 to 6 of 6
Thread: headlights
    kennymact's Avatar
    Sep 2006
    christchurch/newzealand
    headlights
    When I put my headlights on I only get one headlight on dipped but both come on when Main is selected,is this normal as I thought both lo beams come on and both hi when selected...both new bulbs of the same type.
    Dilbert's Avatar
    Apr 2005
    Staffordshire Moorlands
    Re: headlights
    Kenny
    From memory you have an RD03 - yes?
    in which case yes they should both come on, dip and main, check the connector onto the bulbs is secure both sides and fiddle with the Hi/Lo switch, if they come on when you fiddle with the red hi beam button then the contacts are worn which is a pain cos you end up stripping the switch down, losing the spring or the stupid little bits of copper wire that hold the Hi beam engaged and have to buy a new and incredibly expensive switch, don't ask Ok, you don't want to know
    kennymact's Avatar
    Sep 2006
    Re: headlights
    Its an rd04 and the electrician said it was normal and could,nt find anything wrong,I thought that there was 2 relays,one for lo and one for hi but the lecky said no there was only one,I thought I had found a defective red oblong one on the right hand side by the headlight but I have removed that and now only one lo but two hi,bulbs check out ok so I ll try some loose wiring checks....cheers
    Whealie's Avatar
    Lewisham, SE London
    Re: headlights
    That means it is an import. European ones did that. UK ones had both lights on when dipped, so presumably you can change the wiring. Mine has both on all the time.
    kennymact's Avatar
    Sep 2006
    Re: headlights
    Spot on Whealie,the bike is an import and the lecky said it was all working ok..thanks for the info and I ll pass it on to the guys I talked to in the workshop,now I can MOT the beast and do some outstanding trail rides.Oh and the facet pump is on its way
    lowflyer's Avatar
    lowflyer is offline Deer Dodger
    Scottish Highlands
    Re: headlights
    Sooo,
    Is the RD07 different from the RD03 ?
    My RD07 has the same set up as Kennymact. Is mine standard ?
    '96 XRV 750 RD07
    DR 350
    Free beers tomorrow !!!
  1. Headlights
    By markh in forum Africa Twin
    Last Post: 21-12-06, 12:27 PM
  2. headlights abroad
    By Whealie in forum Mechanical Advice
    Last Post: 29-06-06, 04:19 PM
  3. Headlights
    By cabbage2404 in forum Africa Twin
    Last Post: 21-05-06, 02:42 PM
  4. RD07A Headlights
    By Muckybill in forum Africa Twin
    Last Post: 12-05-05, 09:35 AM
  5. headlights abroad
    Last Post: 01-01-70, 12:53 PM
