Results 1 to 10 of 17
Thread: electric start dead
    Whealie's Avatar
    Lewisham, SE London
    electric start dead
    Everything going fine then parked up to collect my daughter from school and ... nothing. All the fuses are fine, all other electrics work fine. The run/stop switch is inthe right place (and had not been touched).
    It bumped started and ran so we got home but the starter button is still dead.
    Answers on a postcard please......
    Finer XRV is offline Member
    May 2006
    London
    Re: electric start dead
    I don't know if this is related but my RD04 will only start if the handlebars are on full lock to the left. If they're in the middle the starter is completely dead.
    Very strange!
    SteveWilko's Avatar
    SteveWilko is offline aka Oxbone :)
    Nuneaton
    Nice one Whealie.....
    I would start with the switch dismantled and check out the connections..... summats gone squiffy.... see if you get a load to the switch, then check to the s/motor...
    or.... It could be a trapped cable thats got chaffed and shorting to earth..
    Pussyhorse's Avatar
    Essex mate
    Could be the starter solenoid/main fuse. IIRC the lights etc will still work if it kills the main fuse.
    Corrosion caused overheating and melted the main fuse/fuse holder on my old RD03. Everything looked ok. The bugger just wouldn't spin over.
    I'm an electrical numpty. I seem to recall the starter span on mine when I shorted the terminals on the solenoid. Shat myself too as I didn't expect it.
    I thoroughly recommend getting a second opinion on anything I say regarding electrics.
    Whealie's Avatar
    Lewisham, SE London
    I think you failed to understand me guys. I wanted an easy answer.
    May 2006
    London
    Hit it with a hammer
    Whealie's Avatar
    Lewisham, SE London
    Quote Originally Posted by Finer XRV View Post
    At last!. I'm back off to the garage immediately.
    Pussyhorse's Avatar
    Essex mate
    More specifically, hit the shiney cylinder to the left of the battery with a hammer.
    Chad's Avatar
    wickford,essex
    if it dont work call me for a big a hammer
    djadams's Avatar
    Mar 2006
    Sussex
    Quote Originally Posted by Chad View Post
  1. electric LED question
    By Eyetee in forum Africa Twin
    Last Post: 24-01-07, 09:27 AM
  2. Cor they did em with an electric start
    By jabba in forum Chatter
    Last Post: 06-10-06, 03:14 PM
  3. Dead AT :(
    Last Post: 24-04-06, 01:53 PM
  4. Dead icu
    By cabbage2404 in forum Transalp
    Last Post: 16-04-06, 12:49 PM
  5. CHAPTER 18 - ELECTRIC STARTER SYSTEM
    Last Post: 26-03-06, 05:44 PM
