Results 1 to 9 of 9
Thread: Back axle
    cip
    cip is offline Junior Member
    Apr 2007
    Bucharest, Romania
    Back axle
    Hi all,
    Please help a noob . I've just bought an 1998 AT, needless to say I am more than happy with her.
    I tried to adjust the chain tension, but that back axle nut is stuck. Is there some kind of safety ? My old Kawasaki had one but I don't see any, on the AT.
    So, my question is: Is there a trick or I just need to use more force (although I've used plenty already ) ?
    Thanks,
    Cip
    Cie's Avatar
    Cie
    Cie is offline Advanced riding bore
    Amesbury, Wilts
    Re: Back axle
    Hi Cip,
    What year/model bike do you have? Things are done differently on the various models.
    '08 KTM 990 Adventure S
    chronyx's Avatar
    Surrey, UK
    Re: Back axle
    A 1998 AT
    You need this thread
    cip
    Apr 2007
    Bucharest, Romania
    Re: Back axle
    Quote Originally Posted by Cie View Post
    Hi Cip,
    1998 RD07
    cip
    Cie's Avatar
    Cie
    Amesbury, Wilts
    Re: Back axle
    Doh!
    Sorry about that
    Well it should just come off then. Maybe it was over-torqued or has seized for some other reason. I'd tried a big arm on the end of a long spanner, then maybe a thump or 3 with a big hammer, then I'd take it to someone who knows.
    Dilbert's Avatar
    Apr 2005
    Staffordshire Moorlands
    Re: Back axle
    Use some Plus Gas or similar on the thread before jumping up and down on the spanner, use a socket and a solid torque arm rather than a rachet and give it a few good raps with a lump hammer to "shock" the thread, Loctite make a spray that's supposed to freeze shock the thread, don't know if anyone's tried it?
    BUT before you do all that make sure the last owner didn't fit a tab washer or pin the nut
    When you put it back lubricate the thread (and the unthreaded part) with a Graphite, Molybdenum or copper grease (or even just a smear of oil) and use an "aerotight" or "nyloc" nut.
    cip
    Apr 2007
    Bucharest, Romania
    Re: Back axle
    Thanks all, that thing was really welded there. I've tried with a loong spanner but it wouldn't budge.
    Finally, I took the bike at a tire shop and they've succeeded (with a bad ass truck tire spanner).
    cip
    Cie's Avatar
    Cie
    Amesbury, Wilts
    Re: Back axle
    Excellent news cip.
    Makes sure it's all cleaned up, greased and torqued properly when it goes back on.
    Dilbert's Avatar
    Apr 2005
    Re: Back axle
    Excellent news cip.
    And fit a new aerotight nut, if it starts binding up when you screw it up run a die down the axle thread to clean off any "pick-up"
  1. Pesky axle clamp bolts!
    By Slimjim in forum Transalp
    Last Post: 21-06-07, 08:59 PM
  2. Cant get the front axle out !
    Last Post: 27-03-07, 09:58 AM
  3. I'm Back
    By Xander in forum Chatter
    Last Post: 22-03-07, 10:15 PM
  4. Visible front axle length
    Last Post: 20-03-06, 06:01 AM
  5. Africa Twin & V-Strom back to back
    By DaveS in forum Chatter
    Last Post: 13-09-05, 11:56 AM
