Results 1 to 9 of 9
Thread: Brake Pads
    sting-stiz's Avatar
    sting-stiz is offline Junior Member
    Apr 2007
    Wigan
    Brake Pads
    Hi Just about to source some brake pads (front) for my AT. There seems to be GG (organic) OR HH (Sintered) which seems to be for off road/race use. Does it matter what I fit (i.e do the HH need uprated matching brake discs????) .
    Martin.
    Gaz's Avatar
    Gaz
    Gaz is offline ... and this is me
    North Wales
    Re: Brake Pads
    Hi Sting-Stiz
    I'm wondering exactly the same thing.
    I've been told by a friend that the sintered are better quality and they should be OK with any discs. If anyone can advise, we'd be grateful
    Gaz
    Mutley's Avatar
    May 2004
    Top of the hill
    Re: Brake Pads
    Just helping to 'bump up' the thread. Someone will surely enlighten us all soon - please!!
    I'm running cast discs at the moment and there doesn't seem to be any real feel to them, I honestly thought they were stronger when I first put them on a few months ago but am now wondering
    Has anyone a preference between the original discs and cast or which pads to use on either.
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: Brake Pads
    Found the following. May help....may not
    CAN I USE ANY BRAKE PAD MATERIAL ON CAST IRON?
    Generally speaking, most organic (semi-metallic) brake pads are good for use on iron rotors. If in doubt, contact the manufacturer for details regarding specific use for this application. Ferodo Platinum, CP911, CP901, 4004F, 3485F, 3410F and I/D450 are all good for this. Although the various sintered metal pads will perform quite well, they generally operate at substantially higher interface temperatures (by as much as 150 degrees [F] at peak). The result is usually shortened life span of the rotor and as such, sintered metal pads are universally not recommended unless specifically denoted otherwise.
    • Gray Iron rotors: Sintered metal pads ARE NOT RECOMMENDED for use under any conditions.
    • Based on extensive dyno testing, results show it is acceptable to run Ferodo SinterGrip ST pads on BrakeTech Ductile Iron rotors (dual disc application only; Buell riders should use either Platinum or CP911 organic pads).
    GSPD750's Avatar
    Re: Brake Pads
    Quote Originally Posted by sting-stiz View Post
    Martin.
    I use EBC sintered HH on my stock discs. p/n FA185R
    They came recommended to me and seem to be wearing
    and performing ok.
    Mutley's Avatar
    May 2004
    Top of the hill
    Re: Brake Pads
    Cheers GSPD750, that's helped a lot thanks with the choice of pads.
    Still not sure which discs/rotors to use though. I'll have to change back and have a play.
    djadams's Avatar
    Mar 2006
    Sussex
    Re: Brake Pads
    Yep, EBC HH used on all my bikes. NB - standard discs are stainless, not cast iron so the quote above is not strictly relevant.
    HH are a massive improvement over stock, highly recommended. They do wear the disc a bit more, but only if you use the fact you can brake harder...
    conkers is offline Muppet
    Apr 2007
    Sweden
    Re: Brake Pads
    I think sintered pads are ok with stainless discs... but don't quote me...
    Does anyone know what material honda used for the discs... I'm assuming 420 grade, but again, I am guessing.
    Does anyone know if carbon metallic pads are available for XRV750?
    I come from racing car world... where everyone is using cast iron discs and carbon metallic pads... they transform the braking of any car... I imagine they would be great on the twin...
    More questions than answers I'm afraid..
    Mike.
    Last edited by conkers; 24-05-07 at 02:27 PM. Reason: because I am a muppet... I told you that already!
    djadams's Avatar
    Mar 2006
    Sussex
    Re: Brake Pads
    Quote Originally Posted by conkers View Post
    They are indeed - The EBC HH I run on my bikes are intended for use on standard stainless rotors or aftermarket cast iron ones. Sorry, just quoted you...
    Not sure how much extra braking power I'd want on the AT - those long travel forks and narrow knobbly tyre don't make for superbike levels of control under heavy braking...
    Last edited by djadams; 26-05-07 at 05:51 PM. Reason: Needed to insert the "Quoting" gag... :)
  1. Brake pads
    By Withen in forum Dominator / FMX
    Last Post: 01-05-07, 08:28 PM
  2. Next Job - Brake pads - help :)
    By Keef in forum Dominator / FMX
    Last Post: 19-04-07, 03:12 AM
  3. Brake Pads
    Last Post: 29-03-07, 03:17 PM
  4. brake pads
    By 5135jimmy in forum Africa Twin
    Last Post: 10-01-07, 10:06 PM
  5. Brake pads
    By lowflyer in forum Africa Twin
    Last Post: 25-11-06, 10:23 PM
