Results 1 to 10 of 14
Thread: oil leak
    Whealie's Avatar
    Lewisham, SE London
    oil leak
    My RD04 has a small oil leak. It has traditionally done this I think but I slightly overfilled the oil recently and it is now worse - it drips when I stop.
    It is leaking from somewhere reasonably high up and dripping onto the chain near the front, so it splashes on tothe oil filter and centre stand etc.
    Any thoughts?
    Xander's Avatar
    Jul 2006
    Lichfield
    Re: oil leak
    Any thoughts?
    I wonder if this is how scotoiler was made....
    you did ask for thoughts... not help....
    I did have a leak from my timing chain adjuster on my CB once... ?? that was reasonably high up.. Just needed a new gasket.. to fix..
    anton88's Avatar
    Re: oil leak
    without looking, i'd guess rear rocker cover gasket is weeping somewhere.
    p.s the i got 2 of the re-cycling boxes off a friend in Suffolk
    SteveWilko's Avatar
    SteveWilko is offline aka Oxbone :)
    Nuneaton
    Re: oil leak
    Overfilling can cause a pressure build up in any engine... check the breather tubes for signs of weeping oil....
    and also.... when you see the leak start to appear.... pull over and pop the dipstick out and use it as a gauge to see the oil level.....
    Next thing to check is for a marking similar to the one below usually located on the crank case....
    TRIUMPH
    Simon Guest
    Re: oil leak
    ...... dripping onto the chain near the front.....
    At least you won't need to buy a scotoiler! Hope you get it sorted.
    sting-stiz's Avatar
    sting-stiz is offline Junior Member
    Apr 2007
    Wigan
    Re: oil leak
    Any thoughts?
    It will prob be from the crankcase breather. When I got my AT it had been overfilled and it blows it out through the breather - pipe ends near front sprocket. Drain a little out and get the oil level and see if it stops (I used a syringe and piece of clear tubing in the filler hole rather than use drain plug). My CRM250 did the same after a few too many wheelies but that dripped onto rear wheel . Just the oil sloshing around.
    Martin.
    xrv_jim's Avatar
    Jul 2004
    Northern Cumbria
    Re: oil leak
    Quote Originally Posted by anton88 View Post
    I think Anton is probably right Whealie, mine 'mists' the top of the rear head/barrel very slightly from the cover gasket, and I've heard of other AT's doing the same. It's a pretty easy job to change the gasket though (on an RD07 anyway!)
    Jim
    '95 R1100GS
    '80 XT250
    Whealie's Avatar
    Lewisham, SE London
    Re: oil leak
    Cheers all,
    I will try to remove some oil (a syringe rather than from the sump and see if that helps). If not, a gasket it will be.
    Chad's Avatar
    wickford,essex
    Re: oil leak
    Cheers all,
    lets just hope its not the output shaft seal anything other than that should be easy to sort
    Dilbert's Avatar
    Apr 2005
    Staffordshire Moorlands
    Re: oil leak
    Quote Originally Posted by xrv_jim View Post
    Sounds favourite, my old CB750 used to do this so I fed the tube into the sprocket cover and clipped it in place, nice warm oil mist onto the chain and it didn't seem to use a huge amount of oil either
    If not then probably the rear rocker cover as above, to check for an oil leak, let it stand till it cools a bit and starts to drip, if you can't see the oil wipe a finger horizontally across the engine (avoid the still hot bits), keep doing this and going higher up the casings till you find the highest spot where there's oil, you just found your leak.
  1. Clutch rod leak or just being paranoid?
    By kevH in forum Africa Twin
    Last Post: 01-06-06, 01:38 PM
  2. Oil Leak
    By Carport in forum Africa Twin
    Last Post: 23-02-06, 06:52 PM
  3. Fuel leak from overflow
    By snaphappyninja in forum Africa Twin
    Last Post: 10-09-05, 12:53 PM
  4. Air leak in the exhaust system
    By kiroh in forum Africa Twin
    Last Post: 12-12-04, 04:23 PM
