Results 1 to 4 of 4
Thread: rear suspension adjustment
    Whealie's Avatar
    Lewisham, SE London
    I know this is possible onthe RD04 but I have never done it. Will it be in the Haynes Manual or is there something obvious?
    I have the side panels and seat off so thought it might be a good time to do this long-standing task.
    anton88's Avatar
    Re: rear suspension adjustment
    Its a bit of a fiddly job - you really need a pre-load spanner to turn the collet to compress the spring if you want to raise the rear ride height a bit.
    I found it best to remove the items youve said, plus the black mudguard under the front of the seat.
    then disconnect/remove everything on/in the airbox so you can unbolt it and move it back out of the way a bit.
    then youve got more access to get at the lockrings on top of the shock - either with the pre-load spanner or if you really must, a suitable drift and hammer.
    Whealie's Avatar
    Lewisham, SE London
    Blimey! Honda made that easy then. Chad, calling Chad.. come in Chad...
    KTiM's Avatar
    KTiM is offline Senior Member
    Jan 2006
    Guernsey, Channel Islands, UK
    Or a long screwdriver and a big hammer ............I'll get my coat, I was going anyway!
  1. REAR SHOCK ABSORBER ADJUSTMENT
    By gs in forum Africa Twin
    Last Post: 18-12-06, 03:23 PM
  2. Vara Rear Suspension
    By Taz in forum Varadero
    Last Post: 18-06-06, 09:17 PM
  3. Rear suspension adjustment
    By ddcristi in forum Africa Twin
    Last Post: 02-09-05, 06:28 AM
  4. Rear Brake Adjustment
    By miggy in forum Africa Twin
    Last Post: 06-03-05, 06:12 AM
  5. rear shock adjustment
    Last Post: 20-08-04, 05:41 PM
