Re: Replacing the master cylinder
Clamp the pipe just below where it joins with the mastercylinder before undoing the banjo bolt. Then just swap the master cylinders, rejoin the brake pipe, fill the mastercylinder with brake fluid and release the clamp. Bleed out the air you've introduced.
I use molegrips with cardboard as protection when clamping brakepipes.
Heating the old copper washers from the pipe joint until cherry red then quenching them in cold water makes them okay to use again if you can't get any new ones.
