Results 1 to 7 of 7
Thread: Noisy Clutch!
    shack's Avatar
    Jun 2007
    Devon knows why I'm so creamy
    Noisy Clutch!
    Hi folks, my clutch is a little noisy at the moment, altough changes into every gear happily, and when I pull the clutch in (in nuetral) the noise goes away, it's not 'loud' but I can here it and just wondering is it a 'feature' or does something need a tweak (or replace) Help appreciated as ever.
    miggy is offline Senior Member
    Jul 2004
    London
    Re: Noisy Clutch!
    What sort of noise?
    xrv_jim's Avatar
    Jul 2004
    Northern Cumbria
    Re: Noisy Clutch!
    Shack,
    AT clutches are known for being a bit noisey. Mine rumbles a bit until you pull the clutch lever in. If it's changing gear OK then I wouldn't worry too much about it.
    Jim
    '95 R1100GS
    '80 XT250
    Cotswolds, UK
    Re: Noisy Clutch!
    That'll be the clutch basket (worn groves). This is quite "normal" for the AT. As long as the plates engage smoothly under acceleration there is no real need to replace the basket.
    chronyx's Avatar
    Surrey, UK
    Re: Noisy Clutch!
    Mine's noisy when I pull the clutch lever in
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: Noisy Clutch!
    Quote Originally Posted by chronyx View Post
    Mine will make a bit of racket too with the clutch lever in. I don't worry about it.
    shack's Avatar
    Jun 2007
    Re: Noisy Clutch!
    Thanks Guys, just wanted a bit of peace of mind about it.
    The @ is still new to me and getting to know its 'ways'
  1. CLUTCH
    Last Post: 15-05-07, 05:32 PM
  2. clutch
    By Mervinh in forum Dominator / FMX
    Last Post: 24-03-07, 09:23 PM
  3. Clutch (less)
    Last Post: 29-08-06, 11:08 PM
  4. Clutch Differences
    By Richard in forum Africa Twin
    Last Post: 22-04-06, 04:52 PM
  5. Clutch tic tic tic
    Last Post: 06-05-05, 12:08 PM
