I think I will take back what I said about the WP stuff after hearing that the 600 forks are of the "modern" type with all the hot prop settings.
It would be a lot easier to get seals for also.
43mm is a very big fork tube!! I really can't see much flexing at all even with the @ weight. Worse case do a fork brace, but I don't think you will need to.
I did a lot of this kind of stuff in California before I moved to the Philippines. I like the idea of a Honda part going on a Honda!!!
Good luck. Keep me posted cause I think I can get a XR600 front end here.
By the way, one single brake disc the size you mentioned would be perfect. You may want to think of the word "Brembo".
