Results 1 to 4 of 4
Thread: Help swopping the Ignition Barrel.
    shack's Avatar
    Jun 2007
    Devon knows why I'm so creamy
    Hi folks, just a quickie, how easy is it to swop the ignition barrel over, it looks like a push fit and life Can't be that simple. one on ebay the finishes v.soon. Still having probs getting keys cut so this might be the solution.
    Thanks as ever.
    lootch67's Avatar
    South Ockendon, Essex
    Re: Help swopping the Ignition Barrel.
    Fairly easy but quite time consuming as you'll have to remove the tank and the air box to plug the wires into the harnass. That's unless you take a shortcut and simply split the original wires.
    shack's Avatar
    Jun 2007
    Thanks for the speedy response, I think I'll pass on that barrel and carry on with the key hunt.
    mal's Avatar
    mal
    mal is offline Senior Member
    Aug 2004
    GLASGOW
    I think you have to drill out the retaining screws to replace, when installed the heads break off ( security feature) someone will correct me if i'm wrong
  1. Ignition Barrel
    By gibbo in forum Africa Twin
    Last Post: 25-03-07, 09:08 PM
  2. Ignition
    By jpc in forum Africa Twin
    Last Post: 18-11-06, 09:59 PM
  3. Ignition Barrel
    By miggy in forum Africa Twin
    Last Post: 28-07-06, 02:40 PM
  4. Double-barrel Scottoiler
    Last Post: 22-01-06, 09:13 PM
  5. No ignition
    Last Post: 11-10-05, 03:34 PM
