Originally Posted by
Jenna
personally i would be a bit cautious of putting any 'u bolt' round any structural part of the frame. To tighten the bolt you need to put a far old clamping force on the section which in turn could under impact (on the bash plate) transmit the force to the frame!!... the lugs are made like that so that any force on them is NOT transmitted further on.
If you must use a u clamp idea i suggest that making from a flat strip of steel that follows the section of the frame and spreads the force more evenly would be a better solution, you can also then drill and tap two bolt holes and fasten front to rear with 2 bolt that's well away from the wheel!
