Got the cheapo carb balancing gauges from Busters and after finding the balance screw (thanks YEN_POWELL for the brilliant picture) got them balanced in no time. The engine runs much smoother and horrible vibration at low revs is gone.
But a few things didn't seem quite right -
Firstly - I had to turn the screw nearly 3/4 of a turn. From what I've read before in this forum the movement should be very slight. Could this be a sticky choke cable?
And also - can anyone tell me what readings should I get on idle and when reving up?
When on idle I got about 11 inches of pressure (between the two red zones), but after slightly revving the engine the pressure dropped to the red zone which reads "Late valve timing or leak at intake manfold or heat riser", then settled on 11 again. Is this expected?
