Results 1 to 3 of 3
Thread: Swollen Leg Muscles
    doctorblow is offline Missing Link
    Durham
    Swollen Leg Muscles
    Went out tonight for the first time in a week,bike started no probs and ran fine for 5 mins and then just stopped(as if i was out of petrol).Checked the tank and it was half full,so i tried to start it again,it ran but it was if i had dirt in the carbs and then it stopped again and wouldn't fire so i pushed it home(hence the swollen leg muscles.)When i got home i tried it again and guess what?The bas***d started and ran fine for 10 mins.Switched it off and tried it again 30 mins later and same again,it ran fine.Is this the start of the dreaded fuel pump problems or was it just muck in the petrol?Any ideas?
    Chad's Avatar
    wickford,essex
    Re: Swollen Leg Muscles
    yup mate odds on its the pump your best option is to go for the facet not that much agro to fit check out the site shop to see if there are any in stock.
    do a serch on the facet pump and you will find lots that we've done with plenty of instructions and tips
    all the best
    chad
    chronyx's Avatar
    Surrey, UK
    Chad could've just hoiked it up under his arm
