Results 1 to 6 of 6
Thread: HELP(please) braided lines +fittings
    tonyk's Avatar
    tonyk is offline Senior Member
    Sep 2006
    DUBLIN
    Hi All,
    I have been searching through threads relating to brake hoses,and came across this,
    http://www.xrv.org.uk/forums/image.p...ine=1172312831 Jenna
    make your own pipes up fron fittings and hose bought per meter, we always changed the MX bike pipes from new to braided.
    best place we found was Rally Design as they have there own brand which is vastly cheaper than the big name brands but exact same quality..
    pipe fittings are at: twin banjo £0.80 and single round eyes £2.40
    http://www.rallydesign.co.uk/catalog...ath=85_248_249
    and pipe is at: £3.50P/mtr
    http://www.rallydesign.co.uk/catalog...ath=85_248_259
    personally i would prefer to use a single banjo and then a 3 way 't' splitting down each fork, double banjos tend to come loose quite easy plus your putting a lot of load on a small ally thread area.
    __________________
    www.RaidXtreme.com
    RAIDXTREME (UK) LTD
    I am going to (find someome who knows what their doing to )replace orignal hoses on my 2001 Rdo7a twin, and plan to buy from the dealer recomend above.
    Before I get on the phone and place on order, would anybody possibly have any acurate info on exact items/sizes of materials I would need to replace front and rear lines
    I have been sent the wrong parts/sizes/lenghts by two different companys as Iam based in Ireland its more of a nuicance to to sort, pain in I am sure youv figured Im a complete tecky ding bat (sorry bout that)but if you could help Id be gratefull,perhaps a contact name in rally design??
    hope you can help,
    Thanks.
    Tony K
    tonyk's Avatar
    Sep 2006
    DUBLIN
    Re: HELP(please) braided lines +fittings
    Hi Ladies+Gents,
    Can anyone confirm actual items / sizes I will need to make up or have rally design make up for me braided hoses front and rear to fit my 2001 @ rdo7a ???
    I have been on the phone to them and without this info they cant help
    been through this a couple of times with other suppliers see previous thread
    any help appriciated,
    Tony K
    BlindPugh's Avatar
    UK
    Here are the parts I used to replace everything from master cylinder down to calipers. Need 1 extra banjo bolt for master cylinder.
    I think the banjo bolts on AT are all M10x1.25pitch - so the ones that Rally Design sell will not fit the calipers or master cylinders.
    Rally Design Parts Used :-
    1 - RD1518 90 DEG Extended Neck Banjo ( master cylinder)
    3 - RDPIPE Euroquip hose 3M ( enough for 3 front , 1 rear hose )
    4 - RD1516 20 DEG Extended Neck Banjo ( 2 x rear hose and 2 for front caliper )
    10 - RD1523 - Copper Washers ( maybe worth getting a couple extra )
    1 - RD1547 - T-Piece M10x1.0 Female ( junction splitter for front brakes)
    3 - RD1501 - M10x1.0 Male Convex Fitting ( hoses into junction splitter)
    4 - RD1512 - Olives ( olives supplied with fittings so these are "just in case" items)
    Well worth getting heatshrink sleeving as the stainless braid is very abrasive.
    Hope this helps
    BP
    tonyk's Avatar
    Sep 2006
    DUBLIN
    Hi BP,
    Just what I needed,big thanks for taking time to respond
    Cheers,
    Tony K
    May 2006
    sorry Tony only just found the PM ( dont bother to check anything other than the main forum postings )
    we dont have a bike here i can get exact thread sizes for the @ from but it looks like BP has sorted that anyway.
    your pobably be dealing with scott or dave at RMD, please say hi from the crew at ADI.
    tonyk's Avatar
    Sep 2006
    DUBLIN
    Thanks Jenna,
    appriciate the response,will give
    regards when I speak with them again,
    cheers
    Tony K
  1. Nonfango fittings
    By High & Mighty in forum Africa Twin
    Last Post: 31-07-09, 09:23 PM
  2. Rear indicator fittings
    By blundering novice in forum XR
    Last Post: 19-06-07, 09:31 PM
  3. Facet pump fittings
    By John in forum Mechanical Advice
    Last Post: 13-07-06, 09:31 PM
  4. STEEL BRAIDED.
    Last Post: 14-04-06, 04:04 AM
  5. Braided lines
    Last Post: 19-07-05, 11:59 AM
