Results 1 to 8 of 8
Thread: primary drive shaft worn
    kennymact's Avatar
    Sep 2006
    christchurch/newzealand
    So,I posted a thread earlier about my drive shaft,slight leak and on investigation find the front sprocket wobbling on the output shaft........pulled off the chain and the front sprocket is in good nick but the shaft has wear marks on it....looks like to change it you have to split the cases.I am gutted as the sprocket would have been easier to replace.The lock plate doesnt seem to be doing much so I thought maybe I ll try a new front sprocket and then check the free play again.I don,t know how long its been like that or how long it will last.How hard is going to be to try and find a new shaft.The local honda dealer here is a complete idiot so I know they won,t be much help.Think I ll take it to one side and start stripping it down and take my time.....
    Muckybill is offline Senior Member
    Whitley Bay
    Re: primary drive shaft worn
    How much play? The sprocket is designed to be a loose fit on the shaft. Are you using a genuine Honda sprocket or a after market one? There is a difference in fit from after market sprockets to Mr Hondas.
    Bill
    GSPD750's Avatar
    Calgary, Alberta Canada
    Muckybill is right. The sprocket will float arount a bit on the shaft. Maybe post some closeup pics of the shaft for us to see. So...the output shaft has no radial play as first thought?
    mrbig is offline Junior Member
    Jul 2007
    As someone who has been through this I deeply sympathize with you.
    Although a little movement (of the sprocket) is acceptable there should be no visible wear of the splines.
    As an alternative to getting an OEM shaft I took the old one to a reputable engineering shop and had them make me a new one at a 1/3 of the cost. The metal must be treated properly for hardening and there can be NO margin for error in manufacture. So keep a keen eye on the progress.
    My #1 tip is to undo the rotor bolt and clutch nut before dropping the engine. This will save you days of heartache and sweat.
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    If the rest of the engine is in good nick dont bother with splitting the cases, weld a sprocket on. I did this for 25,000km ( at about 150,000km ) then ground it off and welded another one on for another 25,000km by then the the rest of the engine needed a freshen up so I split the cases and did it properly
    stageonesimmo's Avatar
    Nov 2006
    Quote Originally Posted by atgreg View Post
    Now THAT ^^^^^^^^^^ is mechanicin' !
    mladen is offline Member
    Slovenija
    I have an AT and TA and both have some freeplay on front sprochet.
    wigs_1's Avatar
    wigs_1 is offline Senior Member
    Jun 2006
    Edinburgh, UK
    I posted a thread about this not long ago.
    Gearbox output shaft wear..??
    Mines ok now despite a bit of wear. Dropping the motor out of the bike and splitting it apart is a pretty big operation and personally I'd only do this if it really needed doing. If your oil leak is less than the amount of oil my scottoiler chucks everywhere then I'm sure you'll be ok
  1. clutch worn?
    By tuggy in forum Africa Twin
    Last Post: 02-04-07, 09:28 PM
  2. worn out camshaft
    By itsgoodtotorque in forum Dominator / FMX
    Last Post: 15-03-07, 11:12 PM
  3. Hmmm...removing a shaft drive?? NTV 650 --> RD03
    By macosie in forum Africa Twin
    Last Post: 01-10-06, 07:52 AM
  4. worn output shaft
    By robbo in forum Africa Twin
    Last Post: 18-09-05, 04:16 PM
  5. worn sproket shaft
    By expat Stu in forum Africa Twin
    Last Post: 12-03-05, 08:31 PM
