Currently doing the full service and I've noticed a few things. As the 5th owner of this bike I'm not expecting it to have been "cherished" however there are a couple of points which don't quite look right but at the same time don't look completely wrong either so I'd appreciate if some of you could head out to your bikes and have a look see if you have anything similar to me. All comments appreciated. Its a 1997 bike by the way.
1) Bike pulls to the right (only a bit when hands are off the bars), prob highlighted by tyre wear. In my experience its usually slightly more on the RHS not the left due to camber in road.
I'm hoping its going to be a twist in the yokes (yet to be checked) BUT I then noticed a few things on the frame.
Dent in RHS of headstock in the corner where the frame, headstock and bracing piece meet.
In the front of the frame approx 6" below the headstock. This one almost looks like its supposed to be there HOWEVER I can't remove the front cylinder exhaust valve cover without loosening the whole rocker coverwhich seems to defeat the point of having a handy little cover.
LHS of the headstock, same place as on RHS.
Finally, what used to be here? Its on the RHS of the frame next to the intake to the front cylinder. One of the previous owners saw fit to remove it using a grinder?? I wonder what they knew that Mr Honda didn't? The one on the LHS of the frame is missing too.
Thanks in advance for your comments.
, we have the benefit of knowing our @s in minute detail so would spot something a miss in a flash.
!Boris!
