Results 1 to 8 of 8
Thread: intermittent fault - poss fuel? Help please
    sam h is offline Junior Member
    WEST LONDON
    The bike starts fine, but.....1/2 mile up the road the engine fades.. almost feels like shes flooding.. After a few mins and a few blips on the starter she goes OK for my 50 mile commute... then its the same problem on the return journey... and it seems to be getting worse and more pronounced. Has anyone on XRV come across a similar problem.
    Any clues would be welcome.
    Sam H
    jonesy's Avatar
    jonesy is offline Gold Member - Yeah baby
    Jul 2006
    Holmfirth
    Re: intermittent fault - poss fuel? Help please
    Fuel pump is my guess, but Chad'll probably give you a full diagnosis!
    WEST LONDON
    Many thanks - the first one died at around 25000 but this second one has been on for the last 100,000 so I guess it could be going..
    BlindPugh's Avatar
    UK
    Fuel pump gets my vote. The do behave oddly when starting to fail.
    Larry Biskit's Avatar
    Larry Biskit is offline Now down under
    Jul 2006
    New Plymouth , New Zealand
    If the pump is a gonner, go the Facet route. Now or later, you'll feel better for it, and its way cheaper than the Honda pump.
    My bike seems smoother, maybe even more responsive... (maybe in the mind) Answers me quicker than the wife does, louder surprisingly too
    doglegdon's Avatar
    Southern Philippines
    Quote Originally Posted by Larry Biskit View Post
    Likewise on the former, certainly not on the latter, unfortunately!
    2008 KTM 990 Adventure S
    Xander's Avatar
    Jul 2006
    Lichfield
    It definitely sound fuel related. It could also be sticking butterflies in the carbs, massively unbalanced carbs, Or the dreaded choke.. If you are not running a facet, i would change that (anyway), get the the carbs cleaned and rebalanced, and lube your choke ... if this does not solve it for years to come.. then you have.. make sure that you fuel lines are not bent in a bad way and make sure that there has not been a build up of crap slowing the flow in the lines/filter (yes I have seen this ...) and.. lastly in the tank the actual fuel tap filter can collapse (seen this too) so if all else fails make sure that this has not happened..
    SteveWilko's Avatar
    SteveWilko is offline aka Oxbone :)
    Nuneaton
    Quote Originally Posted by sam h View Post
    Sam H
    Is it an RD07 or 04 you have?
  1. XL 600 Electrical fault
    By steve g in forum Other Bikes
    Last Post: 06-07-07, 01:20 AM
  2. fuel pumps, it's all your fault!!
    By barftone in forum Chatter
    Last Post: 07-06-07, 08:12 AM
  3. Intermitent fault PLEASE HELP
    By pompyamy in forum Dominator / FMX
    Last Post: 23-05-07, 02:17 PM
  4. its all slimies fault
    By Chad in forum Other Bikes
    Last Post: 20-03-07, 05:36 PM
  5. Intermittent cranking of starter motor
    By Grader in forum Africa Twin
    Last Post: 01-08-05, 09:56 PM
